Summary:
In a rotate_recovery behavior called by move_base, the following code is telling me that getRobotFootprint() has an impossibly big size, and I get a segmentation fault when accessing the first point. Why could it be?
const std::vector<geometry_msgs::Point>& f = local_costmap_->getRobotFootprint();
ROS_ERROR("Size of vector f: %zu", f.size());
for (size_t i = 0; i < f.size(); ++i) {
    const auto& point = f[i];
    ROS_WARN("  x: %.2f, y: %.2f, z: %.2f", point.x, point.y, point.z);
Long story:
I am trying to write my own rotate recovery behavior (https://github.com/ros-planning/navigation/tree/noetic-devel/rotate_recovery).
So to start I am trying to create a plugin that does exactly the same as the above but call it rotate_recovery2.
I literally copied the rotate_recovery folder, changed the name of all rotate_recovery files and folders to rotate_recovery2, change all instances of rotate_recovery to rotate_recovery2 in the CMakeLists and package and rotate_plugin files, and in the rotate_recovery2.cpp and rotate_recovery2.h files, I simply changed the namespace to rotate_recovery2, and in the case of the .cpp file I replaced the import (#include <rotate_recovery2/rotate_recovery2.h>), and the export class (PLUGINLIB_EXPORT_CLASS(rotate_recovery2::RotateRecovery, nav_core::RecoveryBehavior) ).
The code is therefore the same. I have created a new workspace, copied the package inside the src folder, built the package (catkin_make), sourced it.
But if I load the following rosparams:
recovery_behaviors:
  - name: 'costmap_reset_far'
    type: 'clear_costmap_recovery/ClearCostmapRecovery'
  - name: 'costmap_reset_close'
  - name: 'rotate_recovery2'
    type: 'rotate_recovery2/RotateRecovery'
costmap_reset_far:
  reset_distance: 3.0
  layer_names: ["obstacle_laser_layer"]
costmap_reset_close:
  reset_distance: 1.5
rotate_recovery2:
  sim_granularity: 0.017
  frequency: 20.0
  yaw_goal_tolerance: 0.01
  max_rotational_vel: 0.25
  min_in_place_rotational_vel: 0.1
If I run move_base: rosrun move_base move_base odom:=mobile_base_controller/odom cmd_vel:=nav_vel __name:=move_base.
When the robot gets lost I get a Segmentation Fault.
After some debugging, it happens in this line:
double footprint_cost = world_model_->footprintCost(x, y, theta, local_costmap_->getRobotFootprint(), 0.0, 0.0);
I don't know much cpp, but I have been playing with it, and the following:
Prints Size of vector f: 18254858764495155175, which has to be wrong, and when I try to access any element in the footprint, it gives me the segmentation fault.
Why is this happening? How to fix it? I am completely lost, I think the problem is in local_costmap, which is passed by move_base, but I am probably not understanding something.
