I have two cameras subscribing camera1/image_raw and camera2/image_raw respectively. And both subscribers call image_callback when they received any topic. I want to show camera1 image in window1 and camera2 image in window2 while using the same callback function.
So, in the callback function, I would like to determine the topic name (or which subscriber executed the callback function) and if it is camera1, show it in window1 and otherwise in window2.
But, I can't figure out how to determine which subscriber executed the callback in python. Can anyone help me out with this problem? Thank you!
The easiest way is going to be to have two separate callback functions which wrap some common set of code. You can make this a lot cleaner using python's lambda function feature. For example, in ROS 1:
import rospy
def callback(data, source):
    rospy.loginfo(f"I heard {data.data} from {source}")
def listener():
    rospy.init_node('listener', anonymous=True)
    rospy.Subscriber("chatter_1", String, lambda data: callback(data, 1))
    rospy.Subscriber("chatter_2", String, lambda data: callback(data, 2))
    rospy.spin()
if __name__ == '__main__':
    listener()
and in ROS 2:
import rclpy
    rospy.loginfo(f"I heard '{data.data}' from {source}")
def listener():
    rclpy.init()
    node = rclpy.create_node('listener')
    node.create_subscription(String, 'chatter_1', lambda msg: callback(msg, 1), 10)
    node.create_subscription(String, 'chatter_2', lambda msg: callback(msg, 2), 10)
    rclpy.spin(node)
    node.destroy_node()
    rclpy.shutdown()
    listener()
