I would like to debug joint_trajectory_controller in ros_controllers package while running Gazebo and RViz through a launch file generated by MoveIt Setup Assistant:
roslaunch myrobot_moveit_config demo_gazebo.launch
If ros_controllers is installed as a binary, both RViz and Gazebo launch successfully and load controllers: executing a trajectory in RViz after moving the robot arm will cause Gazebo to reflect the arm moving.
Next I follow these instructions to clone and build ros_controllers from source, so that I can debug them:
(instructions from http://wiki.ros.org/ros_control)
cd ~/catkin_ws/src
wstool init
wstool merge https://raw.github.com/ros-controls/ros_control/$ROS_DISTRO-devel/ros_control.rosinstall
wstool update
rosdep install --from-paths . --ignore-src --rosdistro $ROS_DISTRO -y
catkin_make -DCMAKE_BUILD_TYPE=Debug -C ~/catkin_ws
If I launch Gazebo & RViz again, Gazebo Server crashes with this error just after "unpausing physics":
terminate called after throwing an instance of 'std::runtime_error'
what():  Time is out of dual 32-bit range
The controller spawner then exits because it fails to find an instance of controller manager that was supposed to be maintained by Gazebo Server.
If I uninstall ROS, delete Catkin workspace, and then re-install every package it works again, but then I can't debug ros controllers, since it installs as a binary.
This sounds to me like a version mismatch, where the ros_controllers built from source are using a different version of some binary data structure, but I have no idea what it is or how to look for it. I do see that the default branch for ros_controllers is Noetic, which is the correct distribution I am using.
Did anyone get ros controllers built from source? I tried this same thing a few months ago and it appeared to work.
9
  • $\begingroup$ I'm skeptical that the error message is accurate. It's more likely that some required shared library .so file could not be loaded. Please show us the output from echo $LD_LIBRARY_PATH at the point you are ready to do the roslaunch. $\endgroup$
    – Mike973
    Dec 17, 2023 at 14:51
  • $\begingroup$ I am getting the following for $LD_LIBRARY_PATH: ~/catkin_ws/devel/lib:/opt/ros/noetic/lib:/opt/ros/noetic/lib/x86_64-linux-gnu $\endgroup$
    – 01 Binary
    Dec 17, 2023 at 21:05
  • $\begingroup$ I adjusted the launch files to start Gazebo paused, since I had the clue that it crashed just after unpausing. Attached a debugger and clicked Play in Gazebo. Visual Studio broke into joint_state_controller.cpp in function void JointStateController::starting(const ros::Time& time), this line: last_publish_time_ = time - ros::Duration(1.001/publish_rate_); Apparently it crashed because the "time" passed into the function had 0 seconds and 1000000 nano-seconds. It's trying to subtract 1.001 / 50 from this value which would make it negative. $\endgroup$
    – 01 Binary
    Dec 17, 2023 at 22:05
  • $\begingroup$ All right, so I modified the code that was throwing the exception and the joint state controller successfully initializes now. I guess the work-around for this issue has been found, and we'll never know why the code was buggy. auto interval = ros::Duration(1.001 / publish_rate_); if (!pub_time_initialized_ && time.toSec() >= interval.toSec()) /* then initialize publish time */ $\endgroup$
    – 01 Binary
    Dec 17, 2023 at 22:19
    $\begingroup$ Nice work. It's amazing to me that a bug like this could be in there for so long! You should combine your 2 comments into an answer, and ideally show the code change you made. If you have the time, please open a bug report in the github repo & put a link to it in your answer.) $\endgroup$
    – Mike973
    Dec 18, 2023 at 13:29
This was a bug introduced in a recent pull request, which has not yet made it into the apt binary packages so it only reproduces when ros_controllers is build from source.
Created issue #628 in ros_controllers repo.
This bug has now been fixed in https://github.com/ros-controls/ros_controllers/pull/630
