I am trying to achieve sensor fusion between two sensors(camera and lidar). I have two separate node(one is publishing detection results using camera, and other is using lidar and they both are operating on a seperate deep learning based object detection methods) which are publishing detection results in the form of vision_msgs detection array.
Now I want to fuse these detection results. How can I go further? I am using ros2 humble with gazebo fortress and I am trying this experiments in the simulated environment only. (no real sensors)
