I have my 6-axis robot.
ros2 rolling c++
moveit::planning_interface::MoveGroupInterface move_group_interface
After planning the path I use move_group_interface.execute(plan) to move robot.
I'd like to break the motion and stop robot by trigger (for example trigger from external sensor). How can I do that?
I don't see any execute-cancel feature in the moveit2 move_group API. The standard move_group.execute() method passes your trajectory plan to a separate FollowJointTrajectory action server. You can do the same from your own code.
You can create an action client and use it rather than using the move_group.execute() method. That action client object has a cancel operation which should do what you want.
For reference, you can look at the execute() code in move_group_interface.cpp to see how they did it.
  • $\begingroup$ Thanks, I'll check it. $\endgroup$ Dec 14, 2023 at 15:18
