I think that the main issue is that you're trying to read your rotation matrices from left to right. The sign changes seem random, but actually cycle in an ordinary way. Below follows a more elaborate explanation with some more background information.
Let's start with the question:
A) Why do minuses appear at all?
Followed by:
B) Why do minuses appear where they appear?
A)
From a mathematical point of view, it is not possible to construct a strictly positive rotation matrix. This can easily be deduced from the property that rotation matrices are skew-symmetric, i.e. $R=R^{-T}$. As such, it is not possible to define a rotation matrix without minuses or zeros appearing on non-diagonal elements. For example, it is not possible to define (a real number) $\theta$ (representing an angle) in any way to obtain the following matrix and call it a rotation matrix:
$$R\neq\left[\begin{matrix}\cos{\theta} & \sin{\theta} \\ \sin{\theta} & \cos{\theta} \end{matrix}\right]$$
(This matrix is 2D but the same applies to 3D)
A more intuitive explanation is that all three axes of the Cartesian coordinate system are defined to be orthogonal to each other, i.e. at 90 degrees. If mapping a horizontal coordinate component from Y to X requires a rotation of 90 degrees, it follows that mapping from X to Y (i.e. the cross-diagonal element on the rotation matrix) requires a rotation of -90 degrees. The difference between the two is 180 degrees, i.e. a change of sign.
B)
So, minus has to appear somewhere, but why are they appearing as they do? For instance, in a 2D X-Y coordinate system where X is pointing right and Y is pointing up, we could define rotation $\theta$ to be counter-clockwise (cc), or clockwise (c) leading to either of the following two rotation matrices respectively:
$$R_{cc}=\left[\begin{matrix}\cos{\theta} & -\sin{\theta} \\ \sin{\theta} & \cos{\theta} \end{matrix}\right]$$
$$R_{c}=\left[\begin{matrix}\cos{\theta} & \sin{\theta} \\ -\sin{\theta} & \cos{\theta} \end{matrix}\right]$$
As you may already know, we have (nearly) globally accepted to use the former. It is just a convention, defining axes to point to the right and up and the rotation to be counter-clockwise.
Now, let's move to 3D. We cannot simply speak of clockwise and counter-clockwise and right and up anymore, because we are not forced to observe the image from a specific direction. To fix this minor issue, we rewrite our conventions such that they are also applicable in 3D:
1) We use right-handed Cartesian coordinated systems:
2) We use right-handed rotations:
Now, if you look straight at the X-Y coordinate system along Z, we obtain the same coordinate system we had in 2D (Y pointing up, X pointing right). We find that Z is pointing towards you. Due to Z pointing towards you, the rotation will be counter-clockwise and we use the rotation matrix $R_{cc}$.
We can do the same for the Y-Z coordinate system (Z pointing up, Y pointing right), along X. Now X will be pointing towards you. Again, we use $R_{cc}$.
Next, we have the Z-X coordinate system (X pointing up, Z pointing right), along Y. We find exactly the same, i.e. Y pointing towards you. However, Z-X does not appear as obvious in the rotation matrix, because our (flat) matrix has finite width and height rather than being circular.
If you read your rotation matrix from left to right, what appears is the X-Z coordinate system instead of the Z-X coordinate system, also along Y, but now we see that Y is pointing away from you now. This changes the direction of rotation. Hence, you see $R_c$ appearing instead of $R_{cc}$.
Analysing X-Y, Y-Z and Z-X makes more sense than X-Y, Y-Z and X-Z. Try to read your rotation matrix in a more cyclic way, rather than from left to right, if that makes any sense... Try to think of X, Y and Z as independent entities, rather than Y being greater than X and Z being greater than Y, and thus greater than X. Perhaps replace them for apple, orange and banana instead.
