I am trying to run a nxt motor using the mindsensors motor multiplexer at a slow speed. When I turn it on, it tends to jump approx 20 to 40 degrees before moving at a slow speed. Has anyone seen this behavior?
I am using NXT 1.0 with firmware down loaded from lms_arm_mindsensors_129.rfw. Sample code in NXC (I am using Bricx Command Center as my IDE) is as follows:
MMX_Run_Degrees (SensorPort, Addr, MMX_Motor_2, MMX_Direction_Reverse,
     MMX_Speed_Slow, 220, MMX_Completion_Wait_For, MMX_Next_Action_Brake);
Wait(500);
MMX_Run_Unlimited( SensorPort, Addr, MMX_Motor_2,MMX_Direction_Forward, 5);
// The jump happens here.
while(Sensor(IN_2)< SENSORTHRESHOLD);
I have seen this behaviour using the NxtMMX with the EV3 (while writing the driver for ev3dev). I am fairly certain that this is the speed regulation PID overshooting and then slowing down. In NXC you can use MMX_SetPerformanceParameters to change the PID parameters and possibly get rid of the overshoot.
