For a mobile robot - four wheels, front wheel steering - I use the following (bicycle) prediction model to estimate its state based on accurate radar measurements only. No odometry or any other input information $u_k$ is available from the mobile robot itself.
$$ \begin{bmatrix} x_{k+1} \\ y_{k+1} \\ \theta_{k+1} \\ v_{k+1} \\ a_{k+1} \\ \kappa_{k+1} \\ \end{bmatrix} = f_k(\vec{x}_k,u_k,\vec{\omega}_k,\Delta t) = \begin{bmatrix} x_k + v_k \Delta t \cos \theta_k \\ y_k + v_k \Delta t \sin \theta_k \\ \theta_k + v_k \kappa_k \Delta t \\ v_k + a_k \Delta t \\ a_k \\ \kappa_k + \frac{a_{y,k}}{v_{x,k}^2} \end{bmatrix} + \begin{bmatrix} \omega_x \\ \omega_y \\ \omega_{\theta} \\ \omega_v \\ \omega_a \\ \omega_{\kappa} \end{bmatrix} $$
where $x$ and $y$ are the position, $\theta$ is the heading and $v$, $a$ are the velocity and acceleration respectively. Vector $\vec{\omega}$ is zero mean white gaussian noise and $\Delta t$ is sampling time. These mentioned state variables $\begin{bmatrix} x & y & \theta & v & a \end{bmatrix}$ are all measured although $\begin{bmatrix} \theta & v & a \end{bmatrix}$ have high variance. The only state that is not measured is curvature $\kappa$. Therfore it is computed using the measured states $\begin{bmatrix} a_{y,k} & v_{x,k}^2\end{bmatrix}$ which are the lateral acceleration and the longitudinal velocity.
My Question:
Is there a better way on predicting heading $\theta$, velocity $v$, acceleration $a$, and curvature $\kappa$?
  • Is it enough for $a_{k+1}$ to just assume gaussian noise $\omega_a$ and use the previous best estimate $a_k$ or is there an alternative?
  • For curvature $\kappa$ I also thought of using yaw rate $\dot{\theta}$ as $\kappa = \frac{\dot{\theta}}{v_x}$ but then I would have to estimate the yaw rate too.
To make my nonlinear filter model complete here is the measurement model:
$$ \begin{equation} \label{eq:bicycle-model-leader-vehicle-h} y_k = h_k(x_k,k) + v_k = \begin{bmatrix} 1 & 0 & 0 & 0 & 0 & 0 \\ 0 & 1 & 0 & 0 & 0 & 0 \\ 0 & 0 & 1 & 0 & 0 & 0 \\ 0 & 0 & 0 & 1 & 0 & 0 \\ 0 & 0 & 0 & 0 & 1 & 0 \\ \end{bmatrix} \begin{bmatrix} x_k \\ y_k \\ \theta_k \\ v_k \\ a_k \\ \kappa_k \\ \end{bmatrix} + \begin{bmatrix} v_x \\ v_y \\ v_{\theta} \\ v_v \\ v_a \\ \end{bmatrix} \end{equation} $$
More Info on the available data:
The measured state vector is already obtained/estimated using a kalman filter. What I want to achive is a smooth trajectory with the estimate $\kappa$. For this it is a requirement to use another Kalman filter or a moving horizon estimation approach.
5
  • $\begingroup$ May I ask what is the reason for the downvote? $\endgroup$
    – evolved
    Sep 16, 2016 at 11:15
  • $\begingroup$ Sure, i downvoted the question, because matrix oriented prediction model is based on analog pid-controller which are used in the 1930's before the first computers were invented. It is not state-of-the-art. $\endgroup$ Sep 16, 2016 at 12:02
    $\begingroup$ ok this may be the case - that it is not state of the art - but I think this is not a reason to downvote. As this "matrix oriented prediction" is still a possible approach which get's used frequently and I am required to use it. $\endgroup$
    – evolved
    Sep 16, 2016 at 12:23
  • 4
    $\begingroup$ "Not state of the art" is wrong. The IEEE has 20 conference publications, 10 journal articles, and 8 other articles THIS YEAR that discuss both Kalman Filter and State Space control. This is a proven technique that continues to find broad applicability for very challenging control problems. $\endgroup$
    – SteveO
    Sep 16, 2016 at 16:26
  • $\begingroup$ @ManuelRodriguez is right that alternative solutions exist that may be more advanced (though his proposed solution is at best arguably the next candidate), but ultimately incorrect: the Kalman filter is absolutely still (begrudgingly) the state of the art in state estimation. $\endgroup$ Jan 20, 2022 at 16:34
My solution is to use the following model with disturbance only at acceleration and curvature.
$$ \begin{bmatrix} x_{k+1} \\ y_{k+1} \\ \theta_{k+1} \\ v_{k+1} \\ a_{k+1} \\ \kappa_{k+1} \\ \end{bmatrix} = f_k(\vec{x}_k,u_k,\vec{\omega}_k,\Delta t) = \begin{bmatrix} x_k + v_k \Delta t \cos \theta_k \\ y_k + v_k \Delta t \sin \theta_k \\ \theta_k + v_k \kappa_k \Delta t \\ v_k + a_k \Delta t \\ a_k + \omega_a \\ \kappa_k + \omega_{\kappa} \end{bmatrix} $$
-3
Kalman filters and other state-estimation techniques are based on analog computing. In most cases differential equations are used. A better solution is based on grammar techniques aka turing-machines. A paper which is using context free grammars for state-estimation is given here. The idea in short: the measurements are interpreted as a stream of tokens like a computerlanguage and a parser interprets the sentences. To generate such parser motion primitive are used (simple Finite-States-Machines which describes a possible movement of the robot)
  • $\begingroup$ Thanks for your help, I'll try to get some ideas out of the paper. Unfortunately the requeirements are that I use Kalman filters or moving horizon estimation. $\endgroup$
    – evolved
    Sep 16, 2016 at 11:06
  • $\begingroup$ You are welcome, the paper is a declassified version of the "Mercury context free grammar" for radar. $\endgroup$ Sep 16, 2016 at 11:17
  • $\begingroup$ From the cited paper: The more traditional approach such as hidden Markov and state space models are suitable for target modeling [22], [23], but not radar modeling. I think the authors of that paper are solving a much more stochastic problem than you present. If you do not have any other odometry from the mobile robot, then your approach seems reasonable. You might be able to implement a feedforward model to account for friction, inclines, and other nonlinearities, but without local feedback even that would be a challenge. $\endgroup$
    – SteveO
    Sep 16, 2016 at 18:29
    $\begingroup$ This answer is not directed at the question, and is actually somewhat misleading. $\endgroup$ Jan 20, 2022 at 16:36
