So I have this motor: https://www.servocity.com/23-rpm-hd-premium-planetary-gear-motor-w-encoder
and this motor shield for my arduino uno: https://www.pololu.com/docs/pdf/0J49/dual_vnh5019_motor_driver_shield.pdf
And no background in electronics to speak of. I cannot find a basic enough resource to tell me where to attach the wires, or really what they each do. The ones that are simple enough for me only deal with motors with a couple of wires. Information on motors with six wires go immediately to discussing things that are way beyond me, or at least use terms that I don't know.
So the motor has six leads, and the only info I can find on them in the documentation are this: Black (Motor -), Red (Motor +), Green (Ground), Brown (Channel B), Yellow (Channel A), and Orange (Sensor Voltage +).
I have the black and red hooked up to M1A and M1B on my shield, so I am able to turn the motor on, vary its speed and direction. I also had all the other wires hooked up to various pins mentioned in the Demo sketch associated with the shield.
I have spent a week trying to figure this out on my own, but I am not getting anywhere (except that I know that hooking up orange to almost anything triggers a fault).
So in addition to the four wires that are not connected to anything, I have these pins mentioned in the sketch that are also not connected to wires: D2 M1INA, D4 M1INB, D6 M1EN/DIAG, D9 M1PWM and A0 M1CS.
I hope someone can provide a pointer to a resource or a good, plain-language explanation for what these wires and pin descriptions mean. Thanks in advance!
