Can anyone throw some light on using accelerometers to measure angular acceleration and hence angular velocity. This approach is to avoid gyroscopes due to drifting errors. Any links for this also would be very helpful.
Thank you.
Robotics Stack Exchange is a question and answer site for professional robotic engineers, hobbyists, researchers and students. It only takes a minute to sign up.
Sign up to join this communityCan anyone throw some light on using accelerometers to measure angular acceleration and hence angular velocity. This approach is to avoid gyroscopes due to drifting errors. Any links for this also would be very helpful.
Thank you.
Gyros measure angular velocity without the insane drift that comes from integrating accelerometer data. Integrating accelerometers for velocity or position is not a good idea because any noise gets integrated. In theory if the noise was perfectly random this wouldn't be a problem but the noise almost never is.
An accelerometer triad measures the non-field specific force vector ($\mathbf{f}$) at it's location. If it is located at the centre of mass of the body, it will measure $$ \mathbf{f} = \mathbf{\dot{v}} - \mathbf{g} $$ where $\mathbf{\dot{v}}$ is the translational acceleration of the body and $\mathbf{g}$ is the acceleration due to gravity.
To be able to measure angular acceleration around the centre of mass, the accelerometer triad needs to be displaced a distance $\mathbf{\rho}$ from the centre of mass. In that case it will measure $$ \mathbf{f'} = \mathbf{f} + \mathbf{\dot{\omega}\times\rho} +\mathbf{\omega\times}(\mathbf{\omega\times\rho}) $$ where $\mathbf{\omega}$ is the angular velocity of the body. So, to be able to use the accelerometer to (indirectly) measure angular acceleration, you will need to measure the acceleration of the centre of mass as well. This can be done by having two accelerometer triads mounted to the body. Then, you have to solve the equation given above to obtain $\mathbf{\dot{\omega}}$ and integrate it to obtain $\mathbf{\omega}$.
Gyroscopes do drift, yes. But accelerometers also have biases, they are very noisy, and will also measure vibrations in your system. These biases and noises will, of course, be integrated.
Accelerometers (not gyroscopes) are by far the most common way of sensing inclination, in other words the rotation angle relative to "down", and adjusting the mobile phone screen and camera to "portrait mode" or "landscape mode".
Unlike gyroscopes, this method of measuring pitch and roll generally does not have long-term drift (although it often does have a lot of short-term errors).
