I have recently purchased an Orbbec Astra camera, which uses the same technology and produces the same style depth map as a Microsoft Kinect.
What would be the correct file format to save the depth map frames, How would I go about saving the videos recorded?
I have been able to load a stream but am not sure what format the frames should be saved in so that i can load them for testing at a later stage and still have all the same information.
I am using OpenNI2, OpenCV3.1.0 and C++.
If you search a bit you'll find others have all done variations on this approach.
