What is a suitable model for two-wheeled robots? That is, what equations of motion describe the dynamics of a two-wheeled robot.
Model of varying fidelity are welcome. This includes non-linear models, as well as linearized models.
Robotics Stack Exchange is a question and answer site for professional robotic engineers, hobbyists, researchers and students. It only takes a minute to sign up.
Sign up to join this communityWhat is a suitable model for two-wheeled robots? That is, what equations of motion describe the dynamics of a two-wheeled robot.
There isn't a lot of information here. Let's fix the wheels as separated by distance $b$, and each wheel has orientation $\theta_i$ with respect to the line joining them. Then assume each wheel can be independently driven with an angular velocity $v_i$.
If the wheels are independently driven, but fixed in direction, $\theta_1=\theta_2=90^\circ$, you have something like a differential drive (tank treads). It's worth noting that, assuming the wheels do not slip perpandicular to their orientation, you can solve for the motion of the robot base in closed form given velocity commands which are fixed over a small time duration (as is usually the case with robots under software control). The iCreate is such a platform, as are the smaller pioneers, and the Husky by Clearpath. Then the change in orientation of the base, labelled $\theta$ below, can be found in closed form.
The usual model for these things, where $v_b$ is the base velocity and $\omega_b$ is the angular velocity of the base, is:
$$v_b = \frac{1}{2}\cdot(v_1+v_2)$$ $$\omega_b=\frac{1}{b}(v_2-v_1)$$
For a fixed time increment, $\delta t$, you can find the change in orientation, and linear distance traveled using these. Note that the robot travels along a circle in this time window. The distance along the circle is exactly $\delta t\cdot v_b$, and the radius of the circle is $R=\frac{b}{2}\cdot\frac{v_1+v_2}{v_2-v_1}$. That's enough to plug into these equations: circular segments -- particularly the chord length equation, which describes the distance the robot displaces from its original location. We know $R$ and $\theta$, solve for $a$.
So assuming the robot starts with orientation $0$, and position $(0,0)$, and moves along time window $\delta t$ with velocities $v_1$ (left wheel) and $v_2$ (right wheel), it's orientation will be: $$\theta_1=\frac{\delta t}{b}(v_2-v_1)$$ with position: $$p_x=\cos\left(\frac{\theta_1}{2}\right)\cdot\left(2 R \sin\left(\frac{\theta_1}{2}\right)\right)$$ $$p_y=\sin\left(\frac{\theta_1}{2}\right)\cdot\left(2 R \sin\left(\frac{\theta_1}{2}\right)\right)$$
Note that as $v_1\to v_2=v$ the limit is $$p_x=\delta t \cdot v$$ $$p_y=0$$
as expected.
Update why?.
Rearrange $p_x$ so that:
$$ p_x = cos \left( \frac{v_2-v_1}{2b} \right) * 2 * \left( b\frac{v_1+v_2}{2(v_2-v1)} \right) * sin\left( \frac{v_2-v_1}{2b} \right) $$
$$ p_x = cos \left( \frac{v_2-v_1}{2b} \right) * \frac{(v_2+v_1)}{2}* \frac{sin\left( \frac{v_2-v_1}{2b} \right)} {\frac{v_2-v_1}{2b}} $$
Now note that we have three limits as $v_2 \rightarrow v_1$.
$$cos \left( \frac{v_2-v_1}{2b} \right)\rightarrow 1$$
$$ \frac{(v_2+v_1)}{2} \rightarrow v_1 == v_2$$
$$ \frac{sin\left( \frac{v_2-v_1}{2b}\right)}{\frac{v_2-v_1}{2b}} \rightarrow 1 \text{ (see sinc function)}$$
This is covered all over the internet, but you might start here: http://rossum.sourceforge.net/papers/DiffSteer/ or here: https://web.cecs.pdx.edu/~mperkows/CLASS_479/S2006/kinematics-mobot.pdf
If the wheels are not fixed in direction, as in you can vary the speed and orientation, it gets more complicated. In that sense, a robot can become essentially holonomic (it can move in arbitrary directions and orientations on the plane). However, I bet for fixed orientation, you end up with the same model.
There are other models for two wheels, such as a bicycle model, which is easy to imagine as setting the velocities, and only varying one orientation.
That's the best I can do for now.
Px=dt*v
if v1 = v2
. We have sin(theta/2)
as a part of multiplication therefore, when v1=v2 -> theta = 0
, we get sin(0/2)=0
and as a consequence Px = 0
. What I am missing?
Mar 16, 2017 at 13:18
If you really want to dive into the mathematics of it, here's the seminal paper that unified and categorized most models for wheeled robots.
The answer to this is simple, but the other answers obfuscate the dynamics.
Differential drive robots can be modeled with unicycle dynamics of the form: $$\left[\begin{matrix}\dot{x}\\ \dot{y} \\ \dot{\theta} \end{matrix}\right] = \left[\begin{matrix}cos(\theta)&0\\sin(\theta)&0\\0&1\end{matrix}\right] \left[\begin{matrix}v\\\omega\end{matrix}\right],$$ where $x$ and $y$ are Cartesian coordinates of the robot, and $\theta \in (-\pi,\pi]$ is the angle between the heading and the $x$-axis. The input vector $\left[v, \omega \right]^T$ consists of linear and angular velocity inputs.
