I have a custom ROS1 Test.msg message which I use in roscpp Noetic:
uint8[] a
uint8[] b
I use uint8[] to represent strings, because I can't use simple string type in my custom message and I have read that char was deprecated: "char: deprecated alias for uint8" as per https://wiki.ros.org/msg.
When I try to publish a new message of type Test with rostopic echo [TAB][TAB] autocomplete, the following appears:
rostopic pub /myTopic Test "a: !!binary ""
b: !!binary """
How can I use this !!binary "" YAML tag to input a simple string like "test" in the message contents (I can not modify the message definition).
You can do something like this in bash to convert a string to an uint8 array:
rostopic pub /myTopic Test \
  "a: [ \
    $(echo "Hello" | xxd -p -c 1 | xargs -I{} printf "%d\n" 0x{} | paste -sd,) \
This will give you
a: [72, 101, 108, 108, 111, 10]
