I am trying to run the Interactive GPS Waypoint Follower. I have launch these instruction: TERMINAL 1: ros2 launch nav2_gps_waypoint_follower_demo gps_waypoint_follower.launch.py use_rviz:=False TERMINAL 2: ros2 launch nav2_gps_waypoint_follower_demo mapviz.launch.py TERMINAL 3: ros2 run nav2_gps_waypoint_follower_demo interactive_waypoint_follower
When I run interactive_waypoint_follower node and click on mapviz to send waypoint I get fle ollowing output from its terminal(TERMINAL 3):
[INFO] [1701172139.520198172] [basic_navigator]: robot_localization/get_state service not available, waiting...
[INFO] [1701172140.522618706] [basic_navigator]: robot_localization/get_state service not available, waiting...
[INFO] [1701172141.524480719] [basic_navigator]: robot_localization/get_state service not available, waiting...
[INFO] [1701172142.526854488] [basic_navigator]: robot_localization/get_state service not available, waiting...
[INFO] [1701172143.529257288] [basic_navigator]: robot_localization/get_state service not available, waiting...
[INFO] [1701172144.531678462] [basic_navigator]: robot_localization/get_state service not available, waiting...
[INFO] [1701172145.533696952] [basic_navigator]: robot_localization/get_state service not available, waiting...
[INFO] [1701172146.535800306] [basic_navigator]: robot_localization/get_state service not available, waiting...
And this from nav2_gps_waypoint_follower_demo mapviz terminal(TERMINAL 2):
[mapviz-1] [WARN] [1701172112.460493075] [swri_transform_util::Transformer]: Wgs84Transformer not initialized
[mapviz-1] [WARN] [1701172112.460534350] [swri_transform_util::Transformer]: Wgs84Transformer not initialized
[initialize_origin.py-2] [INFO] [1701172112.461930965] [initialize_origin]: Got NavSat message.
[initialize_origin.py-2] [INFO] [1701172112.462575108] [initialize_origin]: Origin from 'navsat' source set to 38.1614564605658, -122.45460714408775, 488.3200360890478
[initialize_origin.py-2] [INFO] [1701172112.463337905] [initialize_origin]: Successfully set origin; unsubscribing.
[mapviz-1] [INFO] [1701172112.480655151] [mapviz]: OK
[mapviz-1] [INFO] [1701172112.482309682] [mapviz]: OK
[mapviz-1] [INFO] [1701172138.485441870] [mapviz]: Point in wgs84: -122.454,38.1612
Why the robot_localization/get_state service is not avaiable? I have not change anything in the example code.
I am using the master branch of navigation2_tutorials
  • $\begingroup$ The gps_waypoint_follower.launch.py wants to add a robot_localization_cmd, which is a reference to dual_ekf_navsat.launch.py. The tutorial (Localization Testing section) says to launch dual_ekf_navsat.launch.py; does it run for you? $\endgroup$
    – Chuck
    Commented Nov 28, 2023 at 15:47
  • $\begingroup$ The other thing that may have been skipped is the robot state publisher; Step 0 in the tutorial says to "test your gazebo world is properly set up by launching: ros2 launch nav2_gps_waypoint_follower_demo gazebo_gps_world.launch.py". That launch file starts a robot state publisher that only appears to get started with this particular launch file. $\endgroup$
    – Chuck
    Commented Nov 28, 2023 at 15:51
Are you using an older version of the nav2 simple commander? It should have a specific call out for robot_localization since its non-lifecycle:
    def waitUntilNav2Active(self, navigator='bt_navigator', localizer='amcl'):
        """Block until the full navigation system is up and running."""
        if localizer != 'robot_localization':  # non-lifecycle node
            self._waitForNodeToActivate(localizer)
        if localizer == 'amcl':
            self._waitForInitialPose()
        self._waitForNodeToActivate(navigator)
        self.info('Nav2 is ready for use!')
        return
  • $\begingroup$ Hi, the problem is I am working on ROS Humble. Reading some post on navigation2 github page I have found that nav2_gps_waypoint_follower is not implemented on Humble(github.com/ros-planning/navigation2/pull/…). Now I am trying to use the Iron version because I specifically need that. At the moment I was able to compile il, but I get this error: [ERROR] [launch]: Caught exception in launch (see debug for traceback): cannot import name 'PushROSNamespace' from 'launch_ros.actions' (/opt/ros/humble/lib/python3.10/site-packages/launch_ros/actions/__init__.py) $\endgroup$ Commented Nov 29, 2023 at 8:39
  • $\begingroup$ Now I am trying to find if a solution exist... $\endgroup$ Commented Nov 29, 2023 at 8:41
  • $\begingroup$ It sounds like you're mixing branches. Use only the proper branch (or just use the binaries) for the distribution you're using only. $\endgroup$ Commented Nov 29, 2023 at 19:11
  • $\begingroup$ I am not mixing branches, I was following the official tutorials using ROS HUMBLE and there is an example about waypoint navigation with GPS. Since I need that feature in my project and I am stuck on ROS Humble for other requirements, NOW I am trying to integrate it from Iron to Humble. Previously in my other posts and in the previously tutorials, I have only use the navigation2 HUBLE branch. If this integration does not end well...I will try to upgrade my ROS from HUMBLE to IRON until JAZZY JALISCO will be released. $\endgroup$ Commented Nov 30, 2023 at 8:47
The only way to have this fixed is upgrade to ROS2 IRON...and use Ubuntu 22.04 I also had these issues and spent a lot of time trying to fix changing classes, passing args etc. Nothing works. Easier way, just go to Iron!
  • $\begingroup$ I know that is an quick solution, but Iron is not a LTS version... $\endgroup$ Commented Feb 1 at 16:01
