As the title mentioned, I want to add a segmentation camera to my robot for a gazebo simulation. I've built my robot using urdf and have already added a realsense d435 cam on it. I do find documents for segmatation camera but there're two problem to it.
  1. It seems that the segmentation cam I found was made for sdf file and didn't mention about how to install it in urdf.
  2. It only works in ignition gazebo. Though I do installed both gazebo and ignition gazebo, I'm currently using gazebo classic and doesn't know how to change my project setup to it.
If there's a way to use realsense's input that was already installed on the robot as the source of the segmentation simulation will be fine too. This is my project in github. Down below is the urdf code of the robot and my installed gazebo version.
Gazebo version 11.14.0.
Gazebo Fortress
ROS 1
forklift.xacro.urdf
<?xml version="1.0"?>
<robot xmlns:xacro="http://www.ros.org/wiki/xacro" name="forklift">
    <link name="base_footprint"/>
    <link name="base_link">
        <inertial>
            <origin xyz="0.0 0.0 0.0" rpy="0.0 0.0 0.0"/>
            <mass value="50.0"/>
            <inertia ixx="0.05" ixy="0.05" ixz="0.05" iyy="1.3419385416666667" iyz="1.3419385416666667" izz="2.296875"/>
            <inertia ixx="1.3419385416666667"
                izz="2.296875"
                ixy="0.0"
                ixz="0.0"
                iyz="0.0"/>
        </inertial>
        <visual name="">
            <geometry>
                <box size="0.525 0.525 0.2155"/>
            </geometry>
            <material name="blue">
                <color rgba="0.0 0.0 1.0 1.0"/>
                <texture filename=""/>
            </material>
        </visual>
        <collision>
            <geometry>
            </geometry>
        </collision>
    </link>
    <gazebo reference="base_link">
        <material>Gazebo/Blue</material>
    </gazebo>
    <joint name="base_joint" type="fixed">
        <parent link="base_footprint"/>
        <child link="base_link"/>
    </joint>
<!--    ***   wheels   ***   -->
    <xacro:macro name="wheel" params="name x y">
        <link name="wheel_link_${name}">
            <inertial>
                <mass value="1.0"/>
                    iyy="0.0009333333333333333" iyz="0.0009333333333333333" izz="0.0018"/>
                <inertia ixx="0.0009333333333333333"
                    izz="0.0018"
                    ixy="0.0"
                    ixz="0.0"
                    iyz="0.0"/>
                </inertial>
            <visual name="">
                <geometry>
                    <cylinder radius="0.06" length="0.02"/>
                </geometry>
                <material name="black">
                    <color rgba="0.0 0.0 0.0 1.0"/>
                </material>
            </visual>
            <collision>
                <geometry>
                </geometry>
            </collision>
        </link>
        <gazebo reference="wheel_link_${name}">
            <material>Gazebo/Black</material>
        </gazebo>
        <joint name="wheel_joint_${name}" type="continuous">
            <origin xyz="${x} ${y} -0.100250" rpy="1.57 0.0 0.0"/>
            <parent link="base_link"/>
            <child link="wheel_link_${name}"/>
            <axis xyz="0.0 0.0 1.0"/>
            <dynamics damping="0.7" friction="0.1" />
        </joint>
    </xacro:macro>
<!--   ***   fork base   ***   -->
    <xacro:macro name="fork_base" params="name y">
        <link name="forkbase_link_${name}">
            <inertial>
                <mass value="0.5"/>
                    iyy="0.0005208333333333334" iyz="0.0004208333333333334" izz="0.00010833333333333334"/>
                <inertia ixx="0.0005208333333333334"
                    iyy="0.0004208333333333334"
                    ixy="0.0"
                    ixz="0.0"
                    iyz="0.0"/>
            </inertial>
            <visual name="">
                <geometry>
                    <box size="0.01 0.05 0.1"/>
                </geometry>
                <material name="green">
                    <color rgba="0.0 1.0 0.0 1.0"/>
                </material>
            </visual>
            <collision>
                <geometry>
                </geometry>
            </collision>
        </link>
        <gazebo reference="forkbase_link_${name}">
            <material>Gazebo/Green</material>
        </gazebo>
        <joint name="forkbase_link_${name}" type="fixed">
            <origin xyz="0.2675 ${y} -0.10025" rpy="0.0 0.0 0.0"/>
            <child link="forkbase_link_${name}"/>
        </joint>
    </xacro:macro>
<!--   ***   fork   ***   -->
    <xacro:macro name="fork_link" params="name">
        <link name="fork_link_${name}">
            <inertial>
                <mass value="0.5"/>
                    iyy="0.00010833333333333334" iyz="0.0026083333333333336" izz="0.0027083333333333334"/>
                <inertia ixx="0.00010833333333333334"
                    iyy="0.0026083333333333336"
                    ixy="0.0"
                    ixz="0.0"
                    iyz="0.0"/>
            </inertial>
            <visual name="">
                <geometry>
                    <box size="0.25 0.05 0.01"/>
                </geometry>
                </material>
            </visual>
            <collision>
                <geometry>
                </geometry>
            </collision>
        </link>
        <gazebo reference="fork_link_${name}">
        </gazebo>
        <joint name="fork_link_${name}" type="fixed">
            <origin xyz="0.13 0 -0.045" rpy="0.0 0.0 0.0"/>
            <parent link="forkbase_link_${name}"/>
            <child link="fork_link_${name}"/>
        </joint>
    </xacro:macro>
    <xacro:include filename="$(find realsense2_description)/urdf/_d435.urdf.xacro" />
    <xacro:sensor_d435 name="camera" topics_ns="camera" parent="base_link" publish_pointcloud="true">
        <origin xyz="0.2625 0 -0.10775" rpy="0 0 0" />
    </xacro:sensor_d435>
<!--   ***   combine component   ***   -->
    <xacro:wheel name="back_right" x="-0.150000" y ="-0.272513"/>
    <xacro:wheel name="back_left" x="-0.150000" y ="0.272513"/>
    <xacro:wheel name="front_right" x="0.150000" y ="-0.272513"/>
    <xacro:wheel name="front_left" x="0.150000" y ="0.272513"/>
    <xacro:fork_base name="right" y ="-0.055"/>
    <xacro:fork_base name="left" y ="0.055"/>
    <xacro:fork_link name="right"/>
    <xacro:fork_link name="left"/>
</robot>
