I have been trying to test some code using an isolated gtest (ament_add_ros_isolated_gtest) that checks the QoS profile used to create a publisher with that reported by the NodeGraphInterface of a node using the get_publishers_info_by_topic function.
Here is an example test that demonstrates the behavior:
TEST(QoS, profile_match)
  const auto topic_name = "/test";
  const auto node = std::make_shared<rclcpp::Node>("test_node");
  rclcpp::QoS qos{rmw_qos_profile_default.depth};
  auto publisher = node->create_publisher<test_msgs::msg::BasicTypes>(topic_name, qos);
  const auto graph_event = node->get_graph_event();
  node->wait_for_graph_change(graph_event, std::chrono::milliseconds{100});
  ASSERT_TRUE(graph_event->check_and_clear());
  const auto topic_endpoints = node->get_publishers_info_by_topic(topic_name);
  ASSERT_EQ(topic_endpoints.size(), std::size_t{1});
  const auto & endpoint_qos = topic_endpoints.front().qos_profile();
  EXPECT_EQ(static_cast<int>(endpoint_qos.history()), static_cast<int>(qos.history()));
  EXPECT_EQ(endpoint_qos.depth(), qos.depth());
and the output of the test:
[----------] 1 test from QoS
[ RUN      ] QoS.profile_match
.cpp:123: Failure
Expected equality of these values:
    Which is: 3
    Which is: 1
.cpp:124: Failure
    Which is: 0
  qos.depth()
    Which is: 10
[  FAILED  ] QoS.profile_match (4 ms)
The QoS profile reported by the get_publishers_info_by_topic has a HistoryProfile of Unknown or int value 3. I assume this is then why the depth() is returning 0.
Does anybody have an idea why there is this mismatch?
Thanks for the help!
