I have successfully installed ROS on Windows and my project is depending on nmea_msgs package. However, when using chocolatey to install nmea_msgs, it failed to find the package.
Command ran:
choco install ros-noetic-nmea-msgs
Result:
Chocolatey v2.0.0
Chocolatey detected you are not running from an elevated command shell
 (cmd/powershell).
 You may experience errors - many functions/packages
 require admin rights. Only advanced users should run choco w/out an
 elevated shell. When you open the command shell, you should ensure
 that you do so with "Run as Administrator" selected. If you are
 attempting to use Chocolatey in a non-administrator setting, you
 must select a different location other than the default install
 location. See
 https://docs.chocolatey.org/en-us/choco/setup#non-administrative-install
 for details.
 Do you want to continue?([Y]es/[N]o): y
Installing the following packages:
By installing, you accept licenses for the packages.
ros-noetic-nmea-msgs not installed. The package was not found with the source(s) listed.
 Source(s): 'https://aka.ms/ros/public;https://chocolatey.org/api/v2/'
 NOTE: When you specify explicit sources, it overrides default sources.
If the package version is a prerelease and you didn't specify `--pre`,
 the package may not be found.
Please see https://docs.chocolatey.org/en-us/troubleshooting for more
 assistance.
Chocolatey installed 0/1 packages. 1 packages failed.
 See the log for details (c:\opt\chocolatey\logs\chocolatey.log).
Failures
 - ros-noetic-nmea-msgs - ros-noetic-nmea-msgs not installed. The package was not found with the source(s) listed.
 assistance.
There aren't as many binary-installable packages on Windows/Chocolatey compared with what's available via apt on Linux. However, the nmea_msgs package is a simple message package with basic dependencies, so it should be straightforward to clone the repo and build it in a Catkin workspace:
https://github.com/ros-drivers/nmea_msgs
It looks like you should check out the master branch to build the package for Noetic.
