I am wondering will if be possible in ROS2 to have 2 different local planners and be able to switch between them.
For example, I want to use both pure-pursuit planner and DWA planner. Let's say that I have a camera that can identify whether if there is any obstacle in front of me. Under normal operation, when there is not obstacle, I want the ros2 planner to use pure-pursuit planner. However, in case of obstacles present, I want the ros2 local planner to switch to using DWA planner instead.I want the ros2 local planner to switch to using DWA planner instead.
Thus, I wonder what I will need to change in my configuration to reflect this feature?
Thanks all in advance!
As far as I know, you can’t change the controller you are using in real time. I think you can only use the one you indicate in the configuration file before the execution.
If you found a way to do this, I would appreciate if you can share how you did it.
