Recently, I've been working on a lidar sensor plugin in Gazebo. I'm attempting to initiate a thread within the sensor plugin to continuously execute 'dSpaceCollide2,' but for some reason, it crashes. The following is what I did:
void Load(sensors::SensorPtr _parent, sdf::ElementPtr sdf)
    // launch a thread to save point cloud
    distortpc_thd = std::make_unique<std::thread>(&DistortPC::DistortPCHandler, this);
void DistortPC::DistortPCHandler()
    // here is the operation invoke GetPhysicsUpdateMutex() and dSpaceCollide2()
    laserShape->GetIntersection(dist, entity);
when i launch gazebo, at random time it crashed. I suspect it's due to multiple threads accessing shared resources. However, when I place this operation in the 'worldUpdateBegin' callback, it works fine.
    // move thread unsafe ops to event handler, and it works normal!
    update_connection_ = event::Events::ConnectWorldUpdateBegin(
        boost::bind(&DistortPC::DistortPCHandler, this));
Yet, I aim to have this operation run continuously rather than waiting for the callback to execute. Could you kindly advise on how to resolve this issue? Or I just want the collison detection like dSpaceCollide2() works instead of the whole physics simulation stuff, how should i disable that? I think only put ray casting on work rather than simulation lower computing load maybe??
Gazebo computes physics updates in the same thread as the worldUpdateBegin event, which is why it worked properly when your code was in that callback. Gazebo also uses 3 separate threads for its sensor updates (Cameras/Rendering sensors, CPU-based Ray sensors, and all other sensors: IMU, Force-torque, etc), so there will be thread synchronization issues if you want to access the physics-based collision data from those threads. I don't think there's an easy answer to this.
