I have a Pi running ROS 2 in Ubuntu. How do you access the Pi's GPIO ports? Is there a library? I'm not sure if I'm running into a ROS 2 or C++ issue.
I've had trouble importing the wiringPi package as there was no .cmake.
CMake Error at CMakeLists.txt:17 (find_package):
  By not providing "FindwiringPi.cmake" in CMAKE_MODULE_PATH this project has
  asked CMake to find a package configuration file provided by "wiringPi",
  but CMake did not find one.
  Could not find a package configuration file provided by "wiringPi" with any
  of the following names:
    wiringPiConfig.cmake
    wiringpi-config.cmake
  Add the installation prefix of "wiringPi" to CMAKE_PREFIX_PATH or set
  "wiringPi_DIR" to a directory containing one of the above files.  If
  "wiringPi" provides a separate development package or SDK, be sure it has
  been installed.
Is it common practice to use someone's pigpio repo as a ROS 2 package?
Resources
6
    $\begingroup$ what have you tried? $\endgroup$
    – jsotola
    Nov 20, 2023 at 20:58
  • $\begingroup$ Welcome to Robotics, but I'm afraid that shopping questions really aren't a good fit for a stack exchange site. We prefer practical, answerable questions based on actual problems that you face. Take a look at How to Ask and tour for more information on how stack exchange works, and the Robotics question checklist for details of how to write a good question. $\endgroup$
    – Tully
    Nov 21, 2023 at 2:34
  • $\begingroup$ I tried to answer it assuming a beginner level learner. @Tully $\endgroup$
    – Robotawi
    Nov 21, 2023 at 2:48
    $\begingroup$ Thanks @Robotawi, you did do your best to provide an answer that could answer one interpretation of the question. There are lots of ways to solve this problem. You've picked one, which I agree is generally reasonable for a potential interpretation of the question. This question does not meet our standards for a good question which is why I closed it. Please read through the links in my comment above for more info. You spent a bunch of time and potentially others will spend a bunch of time trying to answer this question that cannot be effectively answered and would better serve a good question. $\endgroup$
    – Tully
    Nov 21, 2023 at 16:33
  • $\begingroup$ Thanks for revising this. But I'm not going to reopen it. It's now a duplicate of your other question robotics.stackexchange.com/questions/105602/… $\endgroup$
    – Tully
    Nov 22, 2023 at 18:35
Your question about using Rasperry Pi GPIO ports in ROS 2 is an example of combining hardware controller with robotics software frameworks. I mean they are separate, but can be integrated to serve application purpose. Let's break down the integration process in a simple way.
ROS 2: is a framework used in robotics for managing communication and an hardware interfacing.
Raspberry Pi: a computer equipped with general purpose input/output (GPIO) pins. Thosse pins can interface with various electronic components like LEDs, sensors, and motor drives. We can program those pins with Python or C++.
The Integration
Integrating Ras Pi's GPIO functionality with ROS 2 involves creating a ROS 2 node which code interacts with the GPIO pin. This node serves as a bridge, allowing ROS 2 ecosystem to communicate with the Raspberry Pi. Notice we can write code that talks with Ras Pi with nothing to do with ROS at all.
Minimal examples:
(1) Simple Python LED control script
Controlling a LED using the Ras Pi's GPIO:
import RPi.GPIO as GPIO
import time
led_pin = 17  # GPIO pin to which a LED is connected
GPIO.setmode(GPIO.BCM)
GPIO.setup(led_pin, GPIO.OUT)
while True:
    GPIO.output(led_pin, GPIO.HIGH)
    time.sleep(1)
    GPIO.output(led_pin, GPIO.LOW)
    time.sleep(1)
GPIO.cleanup()
(2) Make the previous minimal example a ROS 2 node
Notice how the code that uses the GPIO integrates within the code that makes a ROS 2 node.
import rclpy
from rclpy.node import Node
import time
class LEDBlinkerNode(Node):
    def __init__(self):
        super().__init__('led_blinker')
        self.led_pin = 17
        GPIO.setup(self.led_pin, GPIO.OUT)
        self.timer = self.create_timer(1.0, self.timer_callback)
    def timer_callback(self):
        GPIO.output(self.led_pin, GPIO.HIGH)
        time.sleep(1)
        GPIO.output(self.led_pin, GPIO.LOW)
        time.sleep(1)
def main(args=None):
    rclpy.init(args=args)
    led_blinker_node = LEDBlinkerNode()
    rclpy.spin(led_blinker_node)
    GPIO.cleanup()
    rclpy.shutdown()
if __name__ == '__main__':
    main()
Those examples are about the idea of integrating separate modules to serve the purpose the application. The key takeaway is the adaptability of these systems. Start simple and keep going!
I did not go into the parts of the dependencies installation, which is usually available in documentations. If this is needed, I will enhance the reply.
  • $\begingroup$ Have you ever used wiringPi with C? I got the gpio commands working in the terminal and reflect on the physical wiring but I can't get it to work using the wiringPi library. $\endgroup$
    – Yato
    Nov 28, 2023 at 20:00
Pi GPIO library doesn't interact with ROS2 in any way I know of. Just use it as you would any library. The Pi GPIO deamon doesn't seem to impact ROS2 function either.
