Im quite new to ROS2 humble, so any advice would be appreciated. I am trying to build a socket inside the ROS2 node, so that I can receive some commands from other user. However, I get some build error when I try to build the package. The build error is mainly about:
AttributeError: module 'socket' has no attribute '_GLOBAL_DEFAULT_TIMEOUT'
The code I'm trying to execute is the following:
#!/usr/bin/env python3
# coding=utf-8
import socket
import rclpy
from std_msgs.msg import Char
from std_msgs.msg import Float64
class MySocket:
def __init__(self, sock=None):
if sock is None:
self.sock = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
else:
self.sock = sock
self.host = "192.168.1.125"
self.port = 8
self.MSGLEN = 1024
def connect(self):
self.sock.connect((self.host, self.port))
def mysend(self, msg):
if len(msg) != 1:
raise ValueError("Accepting only the valid commands")
totalsent = 0
while totalsent < 1:
sent = self.sock.send(msg.encode())
if sent == 0:
raise RuntimeError("Socket connection broken")
totalsent += sent
def distSend(self, msg):
if not isinstance(msg, (int, float)):
raise ValueError("Accepting only valid numeric values")
msg_str = str(msg)
totalsent = 0
while totalsent < len(msg_str):
sent = self.sock.send(msg_str[totalsent:].encode())
if sent == 0:
totalsent += sent
def myreceive(self):
received_char = self.sock.recv(1).decode()
if not received_char:
return received_char
global toMaster # command
global toMasterDist # current distance from the wall
def callback(msg: Char):
global toMaster
toMaster = msg.data
def dist_callback(msg: Float64):
global toMasterDist
toMasterDist = msg.data
def main():
rclpy.init()
node = rclpy.create_node('socket')
pub = node.create_publisher(Char, 'from_master', 10)
sub = node.create_subscription(Char, 'to_master', callback, 10)
dist_sub = node.create_subscription(Float64, 'to_master_dist', dist_callback, 10)
s = MySocket()
s.connect()
fm = Char()
while 1:
cmd = s.myreceive()
if cmd == 'M':
fm.data = 109
pub.publish(fm)
while toMaster != 'A':
pass
if toMaster == 'A':
s.mysend('A')
toMaster = '0'
elif cmd == 'D':
fm.data = 100
pub.publish(fm)
pass
if toMaster == 'A':
s.distSend(toMasterDist)
toMaster = '0'
elif cmd == 'F':
fm.data = 102
pub.publish(fm)
pass
if toMaster == 'A':
s.mysend('A')
toMaster = '0'
rclpy.shutdown()
Are there drivers for TCP/IP to communicate with external environment outside of ROS2? Thanks in advance
