I am using ubuntu 20.04 in UTM virtual machine, but gazebo is not properly working. So I decided to install ubuntu 20.04 as dual boot but unable to make in M2 chip, any source from where I can install Ubuntu 20.04 as a dual-boot option with MacOS M2 chip for ROS 1, or is there an alternative method to use ROS 1 on higher version of Ubuntu.
1 Answer
Docker is a good alternative you can try. You can find the docker images for ROS- Distros and gazebo in OSRF Docker Images.
Also, I found this Docker for Robotics playlist quite helpful and easy to understand and there are a lot other resources you can try.
Hope that helps.
