Steps for reproducing the problem with an Intel RealSense D435 camera using ROS Noetic inside a docker.
In the first terminal:
(base) mona@ada:~$ sudo docker run -it --privileged -v /dev:/dev -v /home/mona:/workspace -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY --device /dev/bus/usb ros_noetic
root@7a805700666e:/workspace# cd catkin_ws
(base) mona@ada:~$ docker ps CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES 7a805700666e ros_noetic "/ros_entrypoint.sh …" 4 seconds ago Up 3 seconds clever_feynman
roslaunch realsense2_camera rs_camera.launch align_depth:=true
After capture is done,
5.
root@7a805700666e:/workspace/catkin_ws# catkin_make
Base path: /workspace/catkin_ws
Source space: /workspace/catkin_ws/src
Build space: /workspace/catkin_ws/build
Devel space: /workspace/catkin_ws/devel
Install space: /workspace/catkin_ws/install
#### Running command: "make cmake_check_build_system" in "/workspace/catkin_ws/build"
#### Running command: "make -j32 -l32" in "/workspace/catkin_ws/build"
root@ce71bcbb2d89:/workspace/catkin_ws# source devel/setup.bash
root@ce71bcbb2d89:/workspace/catkin_ws# rosrun bag_converter convert.py
other terminal
$ xhost +local:docker
docker exec -it -e DISPLAY=$DISPLAY clever_feynman bash
run step 3 in this terminal after starting step 4 in the first terminal.root@7a805700666e:/workspace# rosbag record -a -O mona_noetic
Here's the conversion script:
(base) mona@ada:~$ cat catkin_ws/src/bag_converter/scripts/convert.py
#!/usr/bin/python3
import os
import sys
import yaml
from rosbag.bag import Bag
import cv2
import roslib; #roslib.load_manifest(PKG)
import rosbag
import rospy
import cv2
import numpy as np
import argparse
import os
from sensor_msgs.msg import Image
from cv_bridge import CvBridge
from cv_bridge import CvBridgeError
class ImageCreator():
def __init__(self, bagfile, rgbpath, depthpath, rgbstamp, depthstamp):
self.bridge = CvBridge()
with rosbag.Bag(bagfile, 'r') as bag:
for topic,msg,t in bag.read_messages():
print(topic)
if topic == "/camera/color/image_raw":
cv_image = self.bridge.imgmsg_to_cv2(msg,"bgr8")
timestr = "%.6f" % msg.header.stamp.to_sec()
image_name = timestr+ ".png"
cv2.waitKey(1);
cv2.imwrite(rgbpath + image_name, cv_image)
elif topic == "/camera/aligned_depth_to_color/image_raw":
cv_image = self.bridge.imgmsg_to_cv2(msg,"16UC1")
cv2.imwrite(depthpath + image_name, (cv_image).astype(np.uint16))
if __name__ == '__main__':
ImageCreator('/workspace/mona_noetic.bag', '/workspace/mona_noetic/rgb/', '/workspace/mona_noetic/depth/', 1, 1)
However, from the capture, we see this unaligned number of depth aligned frames for rgb and depth:
root@7a805700666e:/workspace# rosbag info mona_noetic.bag
path: mona_noetic.bag
version: 2.0
duration: 18.2s
start: Nov 15 2023 16:04:52.73 (1700064292.73)
end: Nov 15 2023 16:05:10.93 (1700064310.93)
compression: none [41/41 chunks]
types: bond/Status [eacc84bf5d65b6777d4c50f463dfb9c8]
diagnostic_msgs/DiagnosticArray [60810da900de1dd6ddd437c3503511da]
dynamic_reconfigure/Config [958f16a05573709014982821e6822580]
dynamic_reconfigure/ConfigDescription [757ce9d44ba8ddd801bb30bc456f946f]
realsense2_camera/Extrinsics [3627b43073f4cd5dd6dc179a49eda2ad]
realsense2_camera/Metadata [4966ca002be16ee67fe4dbfb2f354787]
rosgraph_msgs/Log [acffd30cd6b6de30f120938c17c593fb]
sensor_msgs/CameraInfo [c9a58c1b0b154e0e6da7578cb991d214]
sensor_msgs/CompressedImage [8f7a12909da2c9d3332d540a0977563f]
sensor_msgs/Image [060021388200f6f0f447d0fcd9c64743]
tf2_msgs/TFMessage [94810edda583a504dfda3829e70d7eec]
theora_image_transport/Packet [33ac4e14a7cff32e7e0d65f18bb410f3]
topics: /camera/align_to_color/parameter_descriptions 1 msg : dynamic_reconfigure/ConfigDescription
/camera/align_to_color/parameter_updates 1 msg : dynamic_reconfigure/Config
/camera/aligned_depth_to_color/image_raw 2 msgs : sensor_msgs/Image
/camera/aligned_depth_to_color/image_raw/compressed/parameter_descriptions 1 msg : dynamic_reconfigure/ConfigDescription
/camera/aligned_depth_to_color/image_raw/compressed/parameter_updates 1 msg : dynamic_reconfigure/Config
/camera/aligned_depth_to_color/image_raw/compressedDepth/parameter_descriptions 1 msg : dynamic_reconfigure/ConfigDescription
/camera/aligned_depth_to_color/image_raw/compressedDepth/parameter_updates 1 msg : dynamic_reconfigure/Config
/camera/aligned_depth_to_color/image_raw/theora/parameter_descriptions 1 msg : dynamic_reconfigure/ConfigDescription
/camera/aligned_depth_to_color/image_raw/theora/parameter_updates 1 msg : dynamic_reconfigure/Config
/camera/color/camera_info 2 msgs : sensor_msgs/CameraInfo
/camera/color/image_raw/compressed 2 msgs : sensor_msgs/CompressedImage
/camera/color/image_raw/compressed/parameter_descriptions 1 msg : dynamic_reconfigure/ConfigDescription
/camera/color/image_raw/compressed/parameter_updates 1 msg : dynamic_reconfigure/Config
/camera/color/image_raw/compressedDepth/parameter_descriptions 1 msg : dynamic_reconfigure/ConfigDescription
/camera/color/image_raw/compressedDepth/parameter_updates 1 msg : dynamic_reconfigure/Config
/camera/color/image_raw/theora/parameter_descriptions 1 msg : dynamic_reconfigure/ConfigDescription
/camera/color/image_raw/theora/parameter_updates 1 msg : dynamic_reconfigure/Config
/camera/depth/camera_info 39 msgs : sensor_msgs/CameraInfo
/camera/depth/image_rect_raw 38 msgs : sensor_msgs/Image
/camera/depth/image_rect_raw/compressed 38 msgs : sensor_msgs/CompressedImage
/camera/depth/image_rect_raw/compressed/parameter_descriptions 1 msg : dynamic_reconfigure/ConfigDescription
/camera/depth/image_rect_raw/compressed/parameter_updates 1 msg : dynamic_reconfigure/Config
/camera/depth/image_rect_raw/compressedDepth 40 msgs : sensor_msgs/CompressedImage
/camera/depth/image_rect_raw/compressedDepth/parameter_descriptions 1 msg : dynamic_reconfigure/ConfigDescription
/camera/depth/image_rect_raw/compressedDepth/parameter_updates 1 msg : dynamic_reconfigure/Config
/camera/depth/image_rect_raw/theora 3 msgs : theora_image_transport/Packet
/camera/depth/image_rect_raw/theora/parameter_descriptions 1 msg : dynamic_reconfigure/ConfigDescription
/camera/depth/image_rect_raw/theora/parameter_updates 1 msg : dynamic_reconfigure/Config
/camera/depth/metadata 37 msgs : realsense2_camera/Metadata
/camera/extrinsics/depth_to_color 1 msg : realsense2_camera/Extrinsics
/camera/realsense2_camera_manager/bond 37 msgs : bond/Status (2 connections)
/camera/rgb_camera/auto_exposure_roi/parameter_descriptions 1 msg : dynamic_reconfigure/ConfigDescription
/camera/rgb_camera/auto_exposure_roi/parameter_updates 1 msg : dynamic_reconfigure/Config
/camera/rgb_camera/parameter_descriptions 1 msg : dynamic_reconfigure/ConfigDescription
/camera/rgb_camera/parameter_updates 1 msg : dynamic_reconfigure/Config
/camera/stereo_module/auto_exposure_roi/parameter_descriptions 1 msg : dynamic_reconfigure/ConfigDescription
/camera/stereo_module/auto_exposure_roi/parameter_updates 1 msg : dynamic_reconfigure/Config
/camera/stereo_module/parameter_descriptions 1 msg : dynamic_reconfigure/ConfigDescription
/camera/stereo_module/parameter_updates 1 msg : dynamic_reconfigure/Config
/diagnostics 68 msgs : diagnostic_msgs/DiagnosticArray
/rosout 88 msgs : rosgraph_msgs/Log (2 connections)
/rosout_agg 38 msgs : rosgraph_msgs/Log
/tf_static 1 msg : tf2_msgs/TFMessage
Further, I see this error when starting the depth align capture:
[ INFO] [1700064224.344956163]: SELECTED BASE:Depth, 0
[ INFO] [1700064224.355172954]: RealSense Node Is Up!
15/11 16:03:44,482 WARNING [140201123149568] (messenger-libusb.cpp:42) control_transfer returned error, index: 300, error: Resource temporarily unavailable, number: b
[ WARN] [1700064224.531686247]:
15/11 16:03:44,873 WARNING [140201123149568] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Resource temporarily unavailable, number: 11
15/11 16:03:44,924 WARNING [140201123149568] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Resource temporarily unavailable, number: 11
15/11 16:03:45,179 WARNING [140201123149568] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Resource temporarily unavailable, number: 11
15/11 16:03:45,230 WARNING [140201123149568] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Resource temporarily unavailable, number: 11
15/11 16:03:45,381 WARNING [140201123149568] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Resource temporarily unavailable, number: 11
15/11 16:03:45,432 WARNING [140201123149568] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Resource temporarily unavailable, number: 11
15/11 16:03:45,584 WARNING [140201123149568] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Resource temporarily unavailable, number: 11
15/11 16:03:45,635 WARNING [140201123149568] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Resource temporarily unavailable, number: 11
15/11 16:03:45,786 WARNING [140201123149568] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Resource temporarily unavailable, number: 11
15/11 16:03:45,837 WARNING [140201123149568] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Resource temporarily unavailable, number: 11
15/11 16:03:45,988 WARNING [140201123149568] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Resource temporarily unavailable, number: 11
15/11 16:03:46,039 WARNING [140201123149568] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Resource temporarily unavailable, number: 11
15/11 16:03:46,191 WARNING [140201123149568] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Resource temporarily unavailable, number: 11
15/11 16:03:46,243 WARNING [140201123149568] (messenger-libusb.cpp:42) control_transfer returned error, index: 768, error: Resource temporarily unavailable, number: 11
[ERROR] [1700064294.457665710]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
15/11 16:04:54,800 ERROR [140200416114432] (uvc-streamer.cpp:106) uvc streamer watchdog triggered on endpoint: 132
[ERROR] [1700064294.983499621]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064295.496846075]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064296.010771429]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064296.478652416]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064296.895753832]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064297.321010419]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064297.747054477]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064298.173193296]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064298.601070803]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064299.022315621]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064299.448716345]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064299.868316530]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064300.287427109]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064300.702281242]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064301.118212082]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064301.540673572]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064301.961749822]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064302.381357661]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064302.799640022]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064303.226624059]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064303.655973210]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064304.081943511]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064304.509441908]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064304.939367902]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064305.369842480]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064305.800837626]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064306.233901531]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064306.662224030]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064307.088729246]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064307.503594745]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064307.920114882]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064308.346923624]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064308.779323394]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064309.224245296]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064309.664677204]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064310.094353804]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064310.524822175]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
[ERROR] [1700064310.940728063]: cv_bridge exception: '[16UC1] is not a color format. but [bgr8] is. The conversion does not make sense'
^C[camera/realsense2_camera-3] killing on exit
[camera/realsense2_camera_manager-2] killing on exit
[rosout-1] killing on exit
[master] killing on exit
shutting down processing monitor...
... shutting down processing monitor complete
done
