I am trying to make a turtlesim script in python, first of all what is difference between "source .../install/setup.bash" ( this works) and "source /opt/ros/humble/setup.bash" ( this doesn't work, it shows package not found) after this when I am running the python script ( I have included Shebang line "#!/usr/bin/env python3")it is showing no executable found, even after execution permission ( chmod +x <script_name>.py) enter image description here
  • $\begingroup$ In the future, make sure to tell us which Operating System and version you are using. But even without that info, @JRTG 's answer is still the right one. $\endgroup$
    – Mike973
    Nov 11, 2023 at 14:20
I suggest to install according to the official install instructions, and then to follow the tutorials.
They explain how to create a package, source the ROS install and your own package, etc.
