Hello Robot Stack Exchange community,
I am currently working with the Stereolabs Zed 2i camera and its ROS wrapper for object detection. I have been exploring the codebase on GitHub and reviewing the documentation on the official website, but I haven't been able to find information on configuring the velocity parameters for object detection.
Specifically, I am interested in understanding which parameter(s) in the Zed 2i ROS wrapper are responsible for providing the velocity of detected objects. I would like to know if there is a way to configure whether the velocity is reported relative to the camera coordinate system or in the above-ground frame. If there is none I also would like to know if I receive the speed relative to the camera or above ground.
I appreciate any insights or guidance on this matter. Thank you!
the reply to your question is implicitly contained in the detected object message. As you can see in the code, the objects message is in camera coordinates: https://github.com/stereolabs/zed-ros2-wrapper/blob/master/zed_components/src/zed_camera/src/zed_camera_component.cpp#L7141
The ZED SDK allows you to change this behavior by setting the value of the parameter RuntimeParameters::measure3D_reference_frame to sl::REFERENCE_FRAME::WORLD instead of sl::REFERENCE_FRAME::CAMERA, but the ROS 2 Wrapper does not allow to select this option.
  • $\begingroup$ When will this feature be added to the ROS 2 Wrapper? $\endgroup$
    – Niklas
    Commented Nov 13, 2023 at 11:14
  • $\begingroup$ This feature would help us as well. $\endgroup$
    – renan
    Commented Nov 14, 2023 at 7:15
  • $\begingroup$ We noted this feature request and it will be added in a future release. $\endgroup$
    – Myzhar
    Commented Dec 4, 2023 at 16:55
