First of all I am a completly beginner in ROS, so I would appreciate your easy explanations...
I am trying to configurate Move_Base_flex. It is an eassy path to be followed, with no obstacles . It is just a robot going throw a broccoli field. I am using Teb_local_planner and GlobalPlanner. The problem seems to be the Teb_local_planer. I think it is just a matter of finding the correct value of each parameter but I am not able to do it... what I have notice is:
  • The robot obscilate following a stright line
  • It turns really slow
  • At certain time it gets crazy and it stops or jump to another line of broccolis.
Beside that, I am using rviz to representate the odometry and the global plan. For some reason, as the robot moves forward, the route already taken by the robot disappears. I would like to take a picture at the end to compare between the path to be followed and the real path followed by the robot. Why does it happend?
This is my repo: https://github.com/julioRF5/Agribot_TFM-MII I am executing:
  • roslaunch agribot_gazebo agribot_farm.launch
  • python load_waypoints_moveBase.py
  • rosrun tf static_transform_publisher 0 0 0 0 0 0 map odom 100
  • roslaunch agribot_navigation agribot_navigation.launch
Thank you so much for the help!!
