Not sure if this is an apt issue or not but so far this is only happening for ros packages.
Having not updated my packages for a long time, it seems apt is stuck trying to upgrade a ros package to a (now outdated and hence nonexistent) version.
e.g. when trying to upgrade ros-noetic-tf2-msgs
Reading package lists... Done
Building dependency tree
The following packages will be upgraded:
ros-noetic-tf2-msgs
1 upgraded, 0 newly installed, 0 to remove and 74 not upgraded.
Need to get 44.4 kB of archives.
After this operation, 0 B of additional disk space will be used.
Err:1 http://packages.ros.org/ros/ubuntu focal/main amd64 ros-noetic-tf2-msgs amd64 0.7.6-1focal.20230620.183347
404 Not Found [IP: 64.50.233.100 80]
E: Failed to fetch http://packages.ros.org/ros/ubuntu/pool/main/r/ros-noetic-tf2-msgs/ros-noetic-tf2-msgs_0.7.6-1focal.20230620.183347_amd64.deb 404 Not Found [IP: 64.50.233.100 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Understandably, the (now outdated) 0.7.6-1focal.20230620.183347
is no longer found since the current version as per here is 0.7.7-1focal.20231013.184042
I've tried different combinations of apt update
, apt clean
, sudo apt install ros-noetic-tf2-msgs=0.7.7-1focal.20231013.184042
but no luck.
Output of apt update
and apt update --fix-missing
shows nothing suspicious. All upgradable packages are ros packages
Hit:16 http://packages.osrfoundation.org/gazebo/ubuntu-stable focal InRelease
Hit:18 http://packages.ros.org/ros/ubuntu focal InRelease
Hit:20 http://packages.ros.org/ros2/ubuntu focal InRelease
Fetched 3,863 kB in 3s (1,163 kB/s)
75 packages can be upgraded. Run 'apt list --upgradable' to see them.
I've also made sure that sources.list
and the keys are set up correctly as of the ubuntu install instructions
apt-cache policy ros-noetic-tf2-msgs
gives
ros-noetic-tf2-msgs:
Installed: 0.7.6-1focal.20221014.220058
Candidate: 0.7.6-1focal.20230620.183347
Version table:
0.7.6-1focal.20230620.183347 500
500 http://packages.ros.org/ros/ubuntu focal/main amd64 Packages
*** 0.7.6-1focal.20221014.220058 100
100 /var/lib/dpkg/status
Any help would be greatly appreciated.
I'm leaving a complete ros reinstall as a last resort
apt upgrade --fix-missing
? $\endgroup$apt update
. I suspect you are actually unable to fetch updates from the ros repos for some reason. $\endgroup$
