I'm facing an issue with installing the robot_upstart package.
whenever i run sudo apt-get install ros-noetic-robot-upstart
,i get an error that says
E: Conflicting values set for option Signed-By regarding source http://packages.ros.org/ros/ubuntu focal: /usr/share/keyrings/ros-archive-keyring.gpg !=
E: The list of sources could not be read.
Looking forward to your reply! Thank you:)
