I believe this is likely a bug. Here is a minimal example and the output with a stack trace (made with backwardcpp):
#include <rclcpp/rclcpp.hpp>
rclcpp::Logger& getLogger() {
  static auto logger = rclcpp::get_logger("moveit");
  return logger;
// make the child logger the first time we use it
rclcpp::Logger getStaticChildLogger()
  static auto logger = [] {
    auto logger = getLogger().get_child("child");
    RCLCPP_INFO(logger, "making the child logger");
    return logger;
  return logger;
int main(int argc, char** argv)
  rclcpp::init(argc, argv);
  rclcpp::Node::SharedPtr node = rclcpp::Node::make_shared("dut_node");
  getLogger() = node->get_logger();
  RCLCPP_INFO(getLogger(), "node logger");
  RCLCPP_INFO(getStaticChildLogger(), "child node logger");
[INFO] [1698780244.672370104] [dut_node]: node logger
[INFO] [1698780244.672399117] [dut_node.child]: making the child logger
[INFO] [1698780244.672402452] [dut_node.child]: child node logger
terminate called after throwing an instance of 'rclcpp::exceptions::RCLError'
  what():  failed to call rcl_logging_rosout_remove_sublogger: Sub-logger 'dut_node.child' not exist., at ./src/rcl/logging_rosout.c:530
Stack trace (most recent call last):
#19   Object "", at 0xffffffffffffffff, in
#18   Object "/home/tyler/code/ws_moveit/install/moveit_core/lib/moveit_core/logger_from_child_dut", at 0x55756bef8624, in _start
#17   Source "../csu/libc-start.c", line 392, in __libc_start_main_impl [0x7fad3c229e3f]
#16   Source "../sysdeps/nptl/libc_start_call_main.h", line 74, in __libc_start_call_main [0x7fad3c229d96]
#15   Source "./stdlib/exit.c", line 143, in exit [0x7fad3c24560f]
#14   Source "./stdlib/exit.c", line 113, in __run_exit_handlers [0x7fad3c245494]
#13   Source "/opt/ros/rolling/include/rclcpp/rclcpp/logger.hpp", line 92, in ~Logger [0x55756bef9467]
         89: rcpputils::fs::path
         90: get_logging_directory();
         91:
      >  92: class Logger
         93: {
         94: public:
         95:   /// An enum for the type of logger level.
#12   Source "/usr/include/c++/11/bits/shared_ptr.h", line 122, in ~shared_ptr [0x55756bef93bd]
        119:    * pointer see `std::shared_ptr::owner_before` and `std::owner_less`.
        120:   */
        121:   template<typename _Tp>
      > 122:     class shared_ptr : public __shared_ptr<_Tp>
        123:     {
        124:       template<typename... _Args>
        125:    using _Constructible = typename enable_if<
#11   Source "/usr/include/c++/11/bits/shared_ptr_base.h", line 1154, in ~__shared_ptr [0x55756bef939d]
       1152:       __shared_ptr(const __shared_ptr&) noexcept = default;
       1153:       __shared_ptr& operator=(const __shared_ptr&) noexcept = default;
      >1154:       ~__shared_ptr() = default;
       1155:
       1156:       template<typename _Yp, typename = _Compatible<_Yp>>
       1157:    __shared_ptr(const __shared_ptr<_Yp, _Lp>& __r) noexcept
#10   Source "/usr/include/c++/11/bits/shared_ptr_base.h", line 705, in ~__shared_count [0x55756bef9ee6]
        702:       ~__shared_count() noexcept
        703:       {
        704:    if (_M_pi != nullptr)
      > 705:      _M_pi->_M_release();
        706:       }
        707:
        708:       __shared_count(const __shared_count& __r) noexcept
#9    Source "/usr/include/c++/11/bits/shared_ptr_base.h", line 168, in _M_release [0x55756befa64c]
        165:    if (__gnu_cxx::__exchange_and_add_dispatch(&_M_use_count, -1) == 1)
        166:      {
        167:             _GLIBCXX_SYNCHRONIZATION_HAPPENS_AFTER(&_M_use_count);
      > 168:        _M_dispose();
        169:        // There must be a memory barrier between dispose() and destroy()
        170:        // to ensure that the effects of dispose() are observed in the
        171:        // thread that runs destroy().
#8    Object "/opt/ros/rolling/lib/librclcpp.so", at 0x7fad3cb27e06, in
#7    Object "/opt/ros/rolling/lib/librclcpp.so", at 0x7fad3cafe6d8, in rclcpp::exceptions::throw_from_rcl_error(int, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, rcutils_error_state_s const*, void (*)())
#6    Object "/usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.30", at 0x7fad3c6ae1fd, in std::rethrow_exception(std::__exception_ptr::exception_ptr)
#5    Object "/usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.30", at 0x7fad3c6ae276, in std::terminate()
#4    Object "/usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.30", at 0x7fad3c6ae20b, in
#3    Object "/usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.30", at 0x7fad3c6a2b9d, in
#2    Source "./stdlib/abort.c", line 79, in abort [0x7fad3c2287f2]
#1    Source "../sysdeps/posix/raise.c", line 26, in raise [0x7fad3c242475]
#0  | Source "./nptl/pthread_kill.c", line 89, in __pthread_kill_internal
    | Source "./nptl/pthread_kill.c", line 78, in __pthread_kill_implementation
      Source "./nptl/pthread_kill.c", line 44, in __pthread_kill [0x7fad3c2969fc]
Aborted (Signal sent by tkill() 1572362 1000)
Aborted (core dumped)
I wrote some documentation here: there is a hash table (__logger_map) that links logger and child logger names to the respective publisher.
I think this is the reason:
  • The node goes out of scope,
  • This calls rcl_logging_rosout_fini_publisher_for_node,
  • which calls _rcl_logging_rosout_remove_logger_map,
  • This iterates through __logger_map and 'unsets' all entries associates with that node,
  • Then the child logger destructs and it fails to find its entry in the __logger_map here.
Quick fix that confirms above:
Change
rclcpp::Node::SharedPtr node = rclcpp::Node::make_shared("dut_node");`
into
static rclcpp::Node::SharedPtr node = rclcpp::Node::make_shared("dut_node");`
And there no longer is an exception, since the node outlives the loggers.
An unrelated remark:
Note that calling get_child on a named logger (i.e. a non-node logger such as rclcpp::get_logger("moveit")) throws an exception (as a named logger does not have a publisher).
So in your example code it is mandatory to issue getLogger() = node->get_logger();, before calling getStaticChildLogger().
7
  • $\begingroup$ wow, thank you for figuring this out. is this what everyone who wants to use child loggers is doing? $\endgroup$ Commented Nov 1, 2023 at 18:34
  • $\begingroup$ side note, i discovered what you wrote about the exception and was trying to work around that here: github.com/ros-planning/moveit2/blob/… $\endgroup$ Commented Nov 1, 2023 at 18:39
  • $\begingroup$ thank you for your documentation, that was excellent, saved me from trying to go read all that rcl code to answer this question. $\endgroup$ Commented Nov 1, 2023 at 18:49
  • $\begingroup$ I think most people use node loggers and child loggers within a node, so it's impossible that the logger outlives the node. $\endgroup$
    – JRTG
    Commented Nov 1, 2023 at 18:56
    $\begingroup$ Glad at least someone read that documentation! ;-) The code is ultimately undocumented unfortunately. $\endgroup$
    – JRTG
    Commented Nov 1, 2023 at 18:57
