For my bachelor project I have to be able to remote control a ur10e robot with gripper in VR. The robot has an adaptive plate attached to its flange, so that it can hold a camera and the gripper. For the VR simulation I use unity and the urdf importer plugin. I could generate the urdf files for the robot and gripper but I only have a STEP(Download files-> Universal Robots-> Mounting CAD-> Coupling and adapter plates) file of the connection piece.
Through previous forum posts I have found out to convert the STEP in dae and stl files and include them in a xacro file
<?xml version="1.0" ?>
<robot name="adapter">
  <link name="world"/>
  <link name="adapter">
    <visual>
      <origin rpy="0 0 0" xyz="0 0 0"/>
      <geometry>
        <mesh filename="package://ur_description/urdf/plate/meshes/Gripper_Adapter.dae" scale="1 1 1"/>
      </geometry>
    </visual>
    <collision>
      <origin rpy="0 0 0" xyz="0 0 0.05"/>
      <geometry>
        <mesh filename="package://ur_description/urdf/plate/meshes/Gripper_Adapter.stl" scale="1 1 1"/>
      </geometry>
    </collision>
  </link>
</robot>
But when I try to transform this xacro to a urdf with the command:
ros2 run xacro xacro $(ros2 pkg prefix ur_description)/share/ur_description/urdf/plate/adapter.urdf.xacro \
name:=adapter > adapter.urdf
It fails. Could anyone please give me some advice? I would appreciate it!
  • $\begingroup$ What means it fails? Could you please add the error/console output? $\endgroup$ Oct 29, 2023 at 13:43
  • $\begingroup$ After rebooting my PC it suddenly worked and I could generate the urdf. I am sorry but I can't remember the error output. $\endgroup$
    – Lapiz
    Oct 30, 2023 at 9:47
First and foremost you miss the joints between links, every link needs a joint connection it to another link (can be fixed to the the world).
Beside that, if you want a functional gripper for simulation this setup won't work either. For a functional gripper you need to have a link for both fingers with a joint so you can control the joint with a movegroup. I would suggest taking a look into the panda arm and how the gripper is defined there.
  • $\begingroup$ Thanks for your answer! I figured that I would need three joints to connect the adapter to the arm, camera and gripper. But I was not sure how it works in relation with the model. When I specify those joints how do I tell they are at the right position of the model? I was thinking of creating a complete urdf then use the moveit setup assistance to generate the msg files so that I can use it in unity $\endgroup$
    – Lapiz
    Oct 30, 2023 at 9:30
