Can someone explain to me the difference between the rclcpp::Qos class and the rclcpp::rmw_qos_profile_t class?
To me, it seems that the first is just an encapsulation of the latter. And if, so, why do some constructors (see rclcpp::Publisher) use rclcpp::Qos and some other (see rclcpp::message_filter::Subscriber) use rclcpp::rmw_qos_profile_t?
The rclcpp::QoS class was introduced here. As the main reason is mentioned: 'Adds an rclcpp version of QoS, which requires the history depth to be specified if using "keep last"'.
why do some constructors use rclcpp::Qos and some other use rclcpp::rmw_qos_profile_t
A quick look through the rclcpp PR's reveals e.g.:
  • This one, introducing rclcpp::QoS for create_client and
  • This one for create_service.
Note that these PR's are a lot more recent than the initial PR introducing rclcpp::QoS.
So I think the reason some constructors still take a rmw_qos_profile_t is probably just because nobody had the time to change those yet.
Side note on the question:
My best-practice to find this kind of knowledge is to:
  • Go to the code in Github,
  • Find a relevant line (e.g. a class definition or a specific method),
  • Click on the line number,
  • Choose 'View git blame' and
  • Read through the pull requests that influenced that part of the code.
This generally leads to design info and discussions about design choices.
Final remark: rmw_qos_profile_t is not part of rclcpp but of rmw. It is defined here.
  • $\begingroup$ Thank you very much! I often get stuck on little details like this and your tips will definitely help me in the future :) $\endgroup$ Commented Oct 26, 2023 at 9:26
