I am trying to use RVIZ2 on Windows 10 with ROS2 Humble, without much success so far. Running (after activating local_setup.ps1
ros2 run rviz2 rviz2
Returns with the message:
[ros2run]: Process exited with failure 3221225595
When running the executable directly:
C:\dev\ros2_humble\bin\rviz2.exe
I get no messages at all, but the exit code is -1073741701.
I can reproduce this with Windows Sandbox (although the numbers are slightly different), with a fresh and default install of Humble.
ROS2 is working normally and I have installed Qt 5.12.12.
What could be the problem here?
