I'm trying to figure out how to use realtime_tools (mainly realtime_publisher&realtime_buffer), but there are to few information about it. I can only find this:
#include <realtime_tools/realtime_publisher.h>
bool MyController::init(pr2_mechanism_model::RobotState *robot,
                        ros::NodeHandle &n)
  realtime_pub = new
    realtime_tools::RealtimePublisher<mgs_type>(n, "topic", 4);
  return true;
void MyController::update()
  if (realtime_pub->trylock()){
    realtime_pub->msg_.a_field = "hallo";
    realtime_pub->msg_.header.stamp = ros::Time::now();
    realtime_pub->unlockAndPublish();
Hope someone can give me more detailed help.
Thanks a lot.
  • $\begingroup$ Please clarify your specific problem or provide additional details to highlight exactly what you need. As it's currently written, it's hard to tell exactly what you're asking. $\endgroup$
    – Community Bot
    Oct 22, 2023 at 12:03
Welcome at RSE.
ros-control is based on a realtime-loop (update methods of the controllers and read/write methods of the hardware components, sharing data with a shared-memory layer). realtime_tools provide mechanisms to use non-realtime-safe code in this loop: E.g., publishers, or buffers exchanging data between the realtime-loop and subscriber callbacks.
It seems that you are working with ROS 1. Both, the buffer and publisher are used in several places of the ros_controllers, or in a simpler form in the control_toolbox's PID implementation
  • $\begingroup$ Thanks for the link. I kinda figure out how to use it. what i'm curious about now is why we use it. $\endgroup$
    – joe qiu
    Oct 23, 2023 at 2:11
  • $\begingroup$ I updated the answer, maybe this helps. $\endgroup$ Oct 23, 2023 at 6:12
