Is there a way to get the package name or directory/location of a running node? Preferably from within a separate python node.
Things I've tried:
  • rosnode info doesn't seem to give any info on which package the node is running in.
  • `rosgraph.masterapi.Master.lookupNode() will give me the IP address, but no package information.
  • I could search for nodes manually using a linux command like locate or `find` for the name, but if there are multiple packages that have the same node name, I won't know which is actually running.
    $\begingroup$ Why exactly do you need the package at runtime? I don't know the answer to your question, but maybe there is an alternative for what you actually want to achieve. $\endgroup$
    – JRTG
    Commented Oct 21, 2023 at 8:35
  • $\begingroup$ Another issue I'll point out is that since ros is a distributed system, the ros package may not even be installed locally on the machine this hypothetical python code is executing on. $\endgroup$
    – Mike973
    Commented Oct 21, 2023 at 12:54
