I am trying to control a Dobot arm. The arm moves with angles whereas I need to work with cartesian coordinates. From inverse kinematics equations and polar coordinates I have implemented x,y and z coordinates working very well on their own. But I can not combine the coordinates in order to work all together. When I add them up it is not going to the desired place. How can I combine these coordinates? I got some help from (https://github.com/maxosprojects/open-dobot) but could not manage to successfully move dobot.
Edit: I've written the codes in Qt and also I've added the triangles used for angle calculations.
//foreArmLength=160mm rearArmLEngth=135mm
float DobotInverseKinematics::gotoX(float x) //func for x-axis
float h=qSqrt(qPow(lengthRearArm,2)-qPow(x,2)); //height from ground
QList<float> zEffect=gotoZ(h); //trying to find the effect of x movement on z-axis
float cosQ=h/lengthRearArm; //desired joint angle
float joint2=qRadiansToDegrees(qAcos(cosQ));
//move in range control
if(joint2 != joint2)
{joint2=0;
qDebug()<< "joint2NAN";}
return joint2;
QList<float> DobotInverseKinematics::gotoY(float y) //func for y-axis
QList<float> result ;
float actualDist=lengthForeArm+distToTool; //distance to the end effector
float x=(qSqrt(qPow(actualDist,2)+qPow(y,2)))-actualDist; //calculating x movement caused by y movement
float joint1=qRadiansToDegrees(qAcos(actualDist/(actualDist+x))); //desired joint angle
float joint2=gotoX(x); //the angle calculation of y movement on x axis
if(joint1 != joint1)
{joint1=0;
qDebug()<< "joint1NAN";}
result.append(joint1);
result.append(joint2);
return result;
QList<float> DobotInverseKinematics::gotoZ(float z) //func. for z-axis
float joint3=qSqrt(qPow(160,2.0)-qPow(z,2.0))/ 160; //desired joint angle
float temp=160-qSqrt(qPow(160,2.0)-qPow(z,2.0));
float joint2=qSqrt(qPow(lengthRearArm,2)-qPow(temp,2.0))/lengthRearArm; //desired joint angle
if(joint3 != joint3)
{joint3=0;
qDebug()<< "joint3NAN";}
joint2=qAcos(joint2)*(180/M_PI);
joint3=qAcos(joint3)*(180/M_PI);
result.append(joint3);
return result;
