Hello my question is whether this type of output is a proper output? I fuse absolute pose from slam and fuse linear velocity from wheel odometry, but the filter output position data is the same as the position data from slam regarding the covariance matrix value from both input source. Is this normal? though if position data from slam got blocked the filter still provide data it got from wheel odometry.
Setup: Ubuntu 18.04 Ros melodic
The "odom_cov_ukf" is from wheel odometry of my differential drive robot and "vo_cov_ukf" is from my slam
this is my configuration.
enter image description here
    $\begingroup$ Welcome at RSE. First of all, please don't post pictures from text. Second, please give more information of your setup, configuration files, ROS distribution etc $\endgroup$ Commented Oct 19, 2023 at 8:58
  • $\begingroup$ You seem to have two accounts: 1 and 2. You can merge the accounts, see this answer. It is rather irregular to gain reputation from suggesting edits to your own posts (as well as posting answers) from a different account.. $\endgroup$ Commented Oct 19, 2023 at 16:31
  • $\begingroup$ Please include your full EKF config (as text), as well as one sample message from every sensor input. $\endgroup$
    – automatom
    Commented Jan 25 at 8:57
