Error in RVIZ
I am using the ROS2 humble SPOT github repo, while installing the package in the workspace and running my first command, I came across this problem.
I tried to check the launch file for any wrong files path but found everything in it's place.
I did not encounter any problems during the installation and everything went well, How can I fix this error and include the world frame.
It looks like from the launch file that you might have to declare a static transform frame called "world", and connect that to the link "body". You can try this out using the following bit of code in the launch file:
import os
import typing
import launch
import launch_ros
from launch.substitutions import (
    Command,
    FindExecutable,
    LaunchConfiguration,
    PathJoinSubstitution,
pkg_share = launch_ros.substitutions.FindPackageShare(package="spot_description").find("spot_description")
default_model_path = os.path.join(pkg_share, "urdf/spot.urdf.xacro")
default_rviz2_path = os.path.join(pkg_share, "rviz/viz_spot.rviz")
def launch_setup(context: launch.LaunchContext) -> typing.List[launch_ros.actions.Node]:
    namespace = LaunchConfiguration("namespace").perform(context)
    robot_description = Command(
            PathJoinSubstitution([FindExecutable(name="xacro")]),
            PathJoinSubstitution([pkg_share, "urdf", "spot.urdf.xacro"]),
            "arm:=",
            LaunchConfiguration("arm"),
            "tf_prefix:=",
            LaunchConfiguration("tf_prefix"),
    robot_state_publisher_node = launch_ros.actions.Node(
        package="robot_state_publisher",
        executable="robot_state_publisher",
        parameters=[{"robot_description": robot_description}],
        namespace=namespace,
    joint_state_publisher_node = launch_ros.actions.Node(
        package="joint_state_publisher",
        executable="joint_state_publisher",
        name="joint_state_publisher",
        condition=launch.conditions.UnlessCondition(LaunchConfiguration("gui")),
    joint_state_publisher_gui_node = launch_ros.actions.Node(
        package="joint_state_publisher_gui",
        executable="joint_state_publisher_gui",
        name="joint_state_publisher_gui",
        condition=launch.conditions.IfCondition(LaunchConfiguration("gui")),
    rviz_node = launch_ros.actions.Node(
        package="rviz2",
        executable="rviz2",
        name="rviz2",
        output="screen",
        arguments=["-d" + default_rviz2_path],
    static_tf_node = launch_ros.actions.Node(
        package="tf2_ros",
        executable="static_transform_publisher",
        output="screen",
        arguments=["0", "0", "0", "0", "0", "0", "world", "body"]
    return [
        joint_state_publisher_node,
        joint_state_publisher_gui_node,
        robot_state_publisher_node,
        rviz_node,
        static_tf_node
def generate_launch_description() -> launch.LaunchDescription:
    launch_arguments = [
        launch.actions.DeclareLaunchArgument(
            name="gui", default_value="True", description="Flag to enable joint_state_publisher_gui"
            name="model", default_value=default_model_path, description="Absolute path to robot urdf file"
            name="rvizconfig", default_value=default_rviz2_path, description="Absolute path to rviz config file"
        launch.actions.DeclareLaunchArgument("arm", default_value="false", description="include arm in robot model"),
            "tf_prefix", default_value='""', description="apply namespace prefix to robot links and joints"
        launch.actions.DeclareLaunchArgument("namespace", default_value="", description="Namespace for robot tf topic"),
    return launch.LaunchDescription(launch_arguments + [launch.actions.OpaqueFunction(function=launch_setup)])
EDIT Added the whole launch file to show the changes a bit better
  • $\begingroup$ I tried adding this code to the launch file "spot_description/launch/description.launch.py", but it did not work, it sais "Node" is undefined. $\endgroup$ Oct 16, 2023 at 8:54
  • $\begingroup$ Yes, you needed to assign it to a variable and then call it in the return. I have updated my answer to show the full piece of code. This change would happen in the launch_setup function. Let's see if this works $\endgroup$
    – ssarkar
    Oct 16, 2023 at 11:47
    $\begingroup$ Yes, that worked. Thank you for the help and for EDIT. really apprciated $\endgroup$ Oct 16, 2023 at 13:15
