What is the best approach to launch a ROS file? Do I need to check that roscore is running before running it?
5
  • $\begingroup$ Welcome to Robotics Stack Exchange! Your question needs more information. For example, what do you mean by "ros driver"? About the roscore, it is started automatically if you execute a roslaunch. Can you please elaborate more on your use case? $\endgroup$
    – ravi
    Commented Oct 10, 2023 at 3:59
  • $\begingroup$ I modified my question to clarify my question. $\endgroup$ Commented Oct 10, 2023 at 4:06
  • $\begingroup$ it deos not start the roscore, I need to start the roscore first and then launch the file. $\endgroup$ Commented Oct 10, 2023 at 4:17
  • $\begingroup$ That's abnormal. Please mention more about the installation and design/configuration of your system. Is your ROS running across multiple machines? As I suggested earlier, the use case should be explained in detail. $\endgroup$
    – ravi
    Commented Oct 10, 2023 at 4:23
  • $\begingroup$ The usecase is an IMU system for a robot, it is running in one computer only $\endgroup$ Commented Oct 10, 2023 at 4:24
According to my understanding of your question, you can launch some files with roslaunch python API and ROSLaunch() call may fail when there's no running ROS Master node available.
Hope this helps.
