I have a node class shown below and I want to call its setCloud method from another class but it gives me the error:
error: ‘using element_type = class rclcpp::Node’ {aka ‘class rclcpp::Node’} has no member named ‘setCloud’ 422 | node_->setCloud(data);
My Node class:
class ROSNode : public rclcpp::Node
public:
    ROSNode() : Node("ros_node")
        msg.header.frame_id = "t";
        points_publisher = this->create_publisher<sensor_msgs::msg::PointCloud2>("/t_points", 10);
    void setCloud(typename pcl::PointCloud<pcl::PointXYZI> cloud)
        pcl::toROSMsg(cloud, msg);
        msg.header.stamp = get_clock()->now();
        points_publisher->publish(msg);
private:
sensor_msgs::msg::PointCloud2 msg;
rclcpp::Publisher<sensor_msgs::msg::PointCloud2>::SharedPtr points_publisher;
Header for the other class:
class testclass{
public:
    testclass();
    virtual ~testclass();
protected:
    ROSNode::SharedPtr node_;
    void transmitTargetDataROS(pcl::PointCloud<pcl::PointXYZI> data);
Source file for the other class:
testclass::testclass(): node_(std::make_shared<ROSNode>())
    rclcpp::spin(node_);
void testclass::transmitTargetDataROS(pcl::PointCloud<pcl::PointXYZI> data)
I copied only relevant parts from the files.
ROSNode::SharedPtr is a typedef inside rclcpp::Node that is always a std::shared_ptr<rclcpp::Node>. As such, it cannot inherit the setCloud method from your custom node.
Juste replace with an explicit std::shared_ptr<ROSNode> and you should be fine.
Not relevant for the question but I do not get the use of typename in the setCloud argument. Additionally, the point cloud could be passed by (const) reference at it is probably a pretty large object.
