I am receiving a sensor_msgs::msg::PointCloud (base_link frame) in my callback. I want to transform this PointCloud to the camera frame, so that I can do a projection of that point cloud view.
I am having problems to convert a sensor_msgs::msg::PointCloud into a pcl::PointCloud<pcl::PointXYZ> cloud; with ROS 2 Foxy. How can I do it?
My CPP code:
void my_callback(const sensor_msgs::msg::PointCloud::SharedPtr msg)
    // cloud_in should be the PointCloud message
    pcl::PointCloud<pcl::PointXYZ> cloud_in;
    pcl::PointCloud<pcl::PointXYZ> cloud_out;
    geometry_msgs::msg::TransformStamped transform;
    try
        transform = tfBuffer_->lookupTransform("camera_frame", msg->header.frame_id, tf2::TimePointZero);
        pcl_ros::transformPointCloud(cloud_in, cloud_out, transform);
    catch (tf2::TransformException &ex)
        RCLCPP_ERROR(this->get_logger(), "Transform error: %s", ex.what());
        return;
  • $\begingroup$ What seems to be the problem in this function? Can you provide the logs of the execution of this node? $\endgroup$
    – ssarkar
    Oct 5, 2023 at 11:51
  • $\begingroup$ as it is it won't do nothing, because my PointCloud msg isn't converted in a pcl::PointCloud<pcl::PointXYZ> as desired $\endgroup$
    – renan
    Oct 5, 2023 at 12:52
Welcome to Robotics Stack Exchange!
I have noticed several concerns with your code snippet, which I would like to address below:
  1. Change the signature of your callback to receive sensor_msgs::msg::PointCloud2 instead of sensor_msgs::msg::PointCloud. Below is an example:
    void my_callback(const sensor_msgs::msg::PointCloud2::SharedPtr msg)
  2. Use pcl::PCLPointCloud2 instead of pcl::PointCloud<pcl::PointXYZ>.
  3. Use pcl_conversions::toPCL to convert sensor_msgs::msg::PointCloud2 to pcl::PCLPointCloud2 as shown below:
    pcl::PCLPointCloud2::Ptr cloud (new pcl::PCLPointCloud2());
    // Convert ROS2 Pointcloud2 to PCL Pointcloud2
    //   Don't foerget to add followings:
    //     #include <pcl_conversions/pcl_conversions.h>
    //     find_package(pcl_conversions REQUIRED)
    pcl_conversions::toPCL(*msg,*cloud);
  4. Finally, you should be able to use pcl_ros::transformPointCloud to transform your point cloud from base_link to camera_link.
  • $\begingroup$ Thanks for your reply, ravi! I am subscribing a topic that publishes a sensor_msgs::msg::PointCloud. I get following output after running ros2 topic list -t: /my/point_cloud [sensor_msgs/msg/PointCloud]. Shouldn't I use then sensor_msgs::msg::PointCloud? $\endgroup$
    – renan
    Oct 5, 2023 at 12:25
  • $\begingroup$ @renan: I am worried seeing old style sensor_msgs::msg::PointCloud in your package. First please subscribe to sensor_msgs::msg::PointCloud2. If it does not work, please see here. On a side note, ROS 2 Foxy is EOL. and will no longer receive support $\endgroup$
    – ravi
    Oct 6, 2023 at 2:58
  • $\begingroup$ With convertPointCloudToPointCloud2 I can now convert my PC to PC2. Thank you. $\endgroup$
    – renan
    Oct 6, 2023 at 8:13
Maybe a good first step is to convert to PointCloud2 using the snippet from convertPointCloudtoPointCloud2 from the package sensor_msgs.
then you can use pcl_conversions::moveToPCL or pcl_conversions::toPCL
    $\begingroup$ Thank you for your input. As @ravi gave me the same answer and some other suggestions, I accepted his, but I appreciate your efforts. Cheers! $\endgroup$
    – renan
    Oct 6, 2023 at 8:15
