We'd like to use crazyswarm2 packages. However we got below error about motion_capture stuff. How to figure out that problem, thanks.
ntukenmez3@ae-icps-407120:~/Documents/crazyswarm2$ source /opt/ros/humble/setup.bash
ntukenmez3@ae-icps-407120:~/Documents/crazyswarm2$ colcon build
Starting >>> crazyflie_interfaces
Finished <<< crazyflie_interfaces [7.81s]
Starting >>> crazyflie_py
Starting >>> crazyflie_sim
Finished <<< crazyflie_py [0.87s]
Starting >>> crazyflie_examples
Finished <<< crazyflie_sim [1.11s]
--- stderr: crazyflie
CMake Error at CMakeLists.txt:18 (find_package):
  By not providing "Findmotion_capture_tracking_interfaces.cmake" in
  CMAKE_MODULE_PATH this project has asked CMake to find a package
  configuration file provided by "motion_capture_tracking_interfaces", but
  CMake did not find one.
  Could not find a package configuration file provided by
  "motion_capture_tracking_interfaces" with any of the following names:
    motion_capture_tracking_interfacesConfig.cmake
    motion_capture_tracking_interfaces-config.cmake
  Add the installation prefix of "motion_capture_tracking_interfaces" to
  CMAKE_PREFIX_PATH or set "motion_capture_tracking_interfaces_DIR" to a
  directory containing one of the above files.  If
  "motion_capture_tracking_interfaces" provides a separate development
  package or SDK, be sure it has been installed.
Failed   <<< crazyflie [1.43s, exited with code 1]
Aborted  <<< crazyflie_examples [0.79s]
Summary: 3 packages finished [9.71s]
  1 package failed: crazyflie
  1 package aborted: crazyflie_examples
  1 package had stderr output: crazyflie
Most likely that your motion_capture_tracking_interfaces package did not compile/is not present.
If the package is present in the same workspace, i.e., if your src directory looks like the following:
src
|-> crazyflie
|-> crazyflie_examples
|-> crazyflie_py
|-> motion_capture_tracking_interfaces
Then you can try compiling the motion_capture_tracking_interfaces package first by using colcon build --packages-select motion_capture_tracking_interfaces.
You should also examine if you made an error (maybe a typo) in the find_packages section of the CMakeLists.txt of the package is calling the correct package name. I have had multiple instances of this error where I mistakenly called find_package(<project>-mgs REQUIRED) which led me to this error.
P.S.: On the off-chance that you might need to actually write the Config.cmake yourself, this answer on StackOverflow is one of the best explanations I have come across.
  • $\begingroup$ I think you were right. Because I run colcon build in a different directory (ntukenmez3@ae-icps-407120:~/Documents/crazyswarm2$ colcon build). So, it did not work. $\endgroup$ Oct 5, 2023 at 15:51
Since I don't have any reputation yet to comment I'll just add this as a separate answer. The documentation for the crazyswarm2 project is here with the installation instructions, to make sure that the packages are in the right folders.
https://imrclab.github.io/crazyswarm2/installation.html
Motion_capture_tracking_interfaces is part of a different package on which crazyswarm2 depends on.
This question was also asked on the project github discussions as well: ros2-crazyswarm2, for more background information.
(I'm a co-maintainer at crazyswarm2).
