First, let me make an observation unrelated to my question: After going through most of the getting started documentation (https://moveit.picknik.ai/main/doc/tutorials/getting_started/getting_started.html), I think it'd be better to base the documentation off of pre-compiled packages, and then move to building your own binaries if it becomes necessary. I'm pretty sure I already had most of the packages I needed installed before I started the MoveIt documentation, so the build errors I've been running into are probably unnecessary. And most have probably been caused by using a WSL2 Ubuntu install on windows, which has a few minor differences (such as a shared PATH environment variable).
That said, I'm running through the MoveIt getting started documentation (in a Windows WSL2 instance) and can't get past the compile step:
colcon build --mixin release
There's the following error:
[Processing: moveit_setup_app_plugins, moveit_setup_controllers, moveit_setup_core_plugins, moveit_setup_srdf_plugins, moveit_task_constructor_visualization]
--- stderr: moveit_task_constructor_visualization
c++: fatal error: Killed signal terminated program cc1plus
compilation terminated.
gmake[2]: *** [motion_planning_tasks/src/CMakeFiles/motion_planning_tasks_rviz_plugin.dir/build.make:203: motion_planning_tasks/src/CMakeFiles/motion_planning_tasks_rviz_plugin.dir/remote_task_model.cpp.o] Error 1
gmake[2]: *** Waiting for unfinished jobs....
gmake[2]: *** [motion_planning_tasks/src/CMakeFiles/motion_planning_tasks_rviz_plugin.dir/build.make:245: motion_planning_tasks/src/CMakeFiles/motion_planning_tasks_rviz_plugin.dir/task_panel.cpp.o] Error 1
gmake[2]: *** [motion_planning_tasks/src/CMakeFiles/motion_planning_tasks_rviz_plugin.dir/build.make:217: motion_planning_tasks/src/CMakeFiles/motion_planning_tasks_rviz_plugin.dir/task_display.cpp.o] Error 1
gmake[1]: *** [CMakeFiles/Makefile2:450: motion_planning_tasks/src/CMakeFiles/motion_planning_tasks_rviz_plugin.dir/all] Error 2
gmake: *** [Makefile:146: all] Error 2
Failed   <<< moveit_task_constructor_visualization [3min 1s, exited with code 2]
Aborted  <<< moveit_setup_core_plugins [9min 32s]
Aborted  <<< moveit_setup_controllers [9min 36s]
Aborted  <<< moveit_setup_srdf_plugins [9min 37s]
Aborted  <<< moveit_setup_app_plugins [9min 38s]
Summary: 54 packages finished [11min 41s]
  1 package failed: moveit_task_constructor_visualization
  4 packages aborted: moveit_setup_app_plugins moveit_setup_controllers moveit_setup_core_plugins moveit_setup_srdf_plugins
  5 packages had stderr output: moveit_configs_utils moveit_setup_controllers moveit_setup_core_plugins moveit_setup_srdf_plugins moveit_task_constructor_visualization
  5 packages not processed
This looks more like a g++ issue than a MoveIt issue. I base my statement on the error message, which says
You can maybe try updating your compiler to the latest version: sudo apt install build-essential and then try to build again.
Also, can you try out a simple build? That would involve not using the --mixin release part of it. AFAIK, the default build type should be release, in order to be optimised for runtime. This would eliminate any extra sources of problems.
It might also be a memory issue, as pointed out in this particular thread. You can try running dmesg right after the build fails to see if it complains about being out of memory or something similar.
    $\begingroup$ It looks like this was a memory issue. I'd forgot to check that after I'd spent days figuring out that the build was failing because Ubuntu was including windows PATHs (which have a different version of ROS2, etc. installed). I added --executor sequential to single-thread the build and it worked (I think). $\endgroup$
    – Josh Mouch
    Commented Oct 4, 2023 at 15:39
