I'm trying to see a point cloud in Rviz but when I add the topic to de Displays i get an error (Rviz) and in the terminal where i opened Rviz I get the following message:
Invalid argument passed to canTransform argument source_frame in tf2 frame_ids cannot be empty
I'm working with OpenDR, specifically with the 3D object detection module.
Warning in terminal:
Warning in terminal
Rviz error:
Rviz error
I'm trying to see other people's responses with the same issue, I have already tried it everything but this information is not valid for me.
The output of rostopic echo /tf:
transforms:
header:
  seq: 0
  stamp:
    secs: 1696351719
    nsecs: 943305939
  frame_id: "map"
child_frame_id: "base_link"
transform:
  translation:
    x: 0.0
    y: 0.0
    z: 0.0
  rotation:
    x: 0.0
    y: 0.0
    z: 0.0
    w: 1.0**
for rostopic echo /opendr/dataset_point_cloud the output is:
header:
  seq: 10053
  stamp:
    secs: 1696352933
    nsecs:   3319978
  frame_id: ''
points: "<array type: geometry_msgs/Point32, length: 18911>"
channels: "<array type: sensor_msgs/ChannelFloat32, length: 1>"
8
  • $\begingroup$ Please post error messages as text and not as screenshots, because images are not text searchable. $\endgroup$ Oct 3, 2023 at 11:02
  • $\begingroup$ Can you please check the frame id the pointcloud is refered to? Try using ros2 topic echo /opendr/dataset_point_cloud. $\endgroup$ Oct 3, 2023 at 12:16
  • $\begingroup$ @DiegoCarvajal Hi, I'm using ROS1 and when I use echo for /opendr/dataset_point_cloud I get a huge matrix of numbers and x,y,z coordinates but no information about the frame id. Also, when I use rostopic echo /tf I get the following info: frame_id: "map" and child_frame_id: "base_link" $\endgroup$
    – ARosOpenDR
    Oct 3, 2023 at 14:33
  • $\begingroup$ @ARosOpenDR Can you please edit the question and add the output from rostopic echo /opendr/dataset_point_cloud and rostopic echo /tf so we can check the info. $\endgroup$ Oct 3, 2023 at 16:31
  • $\begingroup$ The output of rosrun tf2_tools view_frames.py is more useful than the raw topic output of /tf $\endgroup$
    – Tully
    Oct 3, 2023 at 16:57
The error means that can_transform is being invoked with an empty string as the frame_id. As there doesn't appear to be any issues with your transform tree it's mostly likely that the data in your dataset that you're playing back does not have the frame_id fields properly set.
  • $\begingroup$ How can I set correctly the frame_id fields? I don't understand very good how to do it. When I launch point_cloud_dataset_node.py I get this: Downloading KITTI Dataset zip file from opendrdata.csd.auth.gr/perception/object_detection_3d/… to KITTI So I suppose that this dataset is set wrong? $\endgroup$
    – ARosOpenDR
    Oct 3, 2023 at 18:02
  • $\begingroup$ The dataset does not contain that information. It's not complete for your use case. I would recommend using the rosbag API to iterate through the bag files and rewrite the frame_ids before you play them back: There's example scripts at wiki.ros.org/rosbag/Cookbook $\endgroup$
    – Tully
    Oct 3, 2023 at 21:38
  • $\begingroup$ To close the loop, your echo of the bag file confirms that the frame_ids are not set which was what I guessed the problem was. $\endgroup$
    – Tully
    Oct 3, 2023 at 21:39
