I am trying to get the following setup by command line, but it is not working (Ros2, Galactic, fastrtps): I would like to setup a set of ROS2 nodes partitioned by multiple discovery servers. I would like to have these discovery-servers on different machines but at the moment let's take the topology of option2 of this document, so consider just one machine. We have 2 discovery server (DS1 and DS2) with a publisher (P) referring to DS1 and a subscriber (S) referring to DS2: P -> DS1 <-> DS2 <- S. My question is "Can I get the servers talking to each other from command line"? According to this page , if I got it right, it is possible prefixing to one of the servers the reference to the other via "export ROS_DISCOVERY_SERVER" (so one server becomes a "client" of the other). All in all, I have the following configuration:
TERMINAL1 (DS1):
source /opt/ros/galactic/setup.sh
export RMW_IMPLEMENTATION=rmw_fastrtps_cpp
fastdds discovery -i 0 -l 192.168.1.188 -p 11811
TERMINAL2 (DS2):
export ROS_DISCOVERY_SERVER="192.168.1.188:11811"
fastdds discovery -i 1 -l 192.168.1.188 -p 11812
TERMINAL3 (P)
ros2 run demo_nodes_cpp talker --ros-args --remap __node:=talker_discovery_server
TERMINAL4 (S):
export ROS_DISCOVERY_SERVER="192.168.1.188:11812"
ros2 run demo_nodes_cpp listener --ros-args --remap __node:=listener_discovery_server
If this can not be achieved via shell commands, to my understanding I can take point to an xml config file (like this) via FASTRTPS_DEFAULT_PROFILES_FILE, but then how should I use it? With one server I would just launch "fastdds discovery -i 0" but here there are multiples..
Thanks
I think I have found the solution (here for details): when setting the ROS_DISCOVERY_SERVER environmental variable one needs to specify the IP address in the "right slot". So each IP address needs to match the corresponding discovery server id: below a working example with discovery servers on different machines:
MACHINE1-TERMINAL1 (discovery server '0'):
MACHINE1-TERMINAL2 (discovery server '1'):
export ROS_DISCOVERY_SERVER="192.168.1.188:11811;192.168.1.188:11812;"
MACHINE1-TERMINAL3 (talker via server '1'):
export ROS_DISCOVERY_SERVER=";192.168.1.188:11812;"
MACHINE1-TERMINAL4 (listener via server '0'):
export ROS_DISCOVERY_SERVER="192.168.1.188:11811;;"
MACHINE2-TERMINAL1 (discovery server '2'):
export ROS_DISCOVERY_SERVER="192.168.1.188:11811;;192.168.1.248:11813"
fastdds discovery -i 2 -l 192.168.1.248 -p 11813
MACHINE2-TERMINAL2 (listener on MACHINE2):
export ROS_DISCOVERY_SERVER=";;192.168.1.248:11813;"
However sometimes one of the listener doesn't output anything till I restart the 'related' discovery server: is there an error in the above example or how should one detect/cope with such behaviors when for example working out in the field?
Thanks
