I have just gotten my first diffdrive hardware interface to run, connected to a RPi Pico running Micro-ROS. My launch file is pretty much identical to the demo:
ROS2 Control diffbot demo launch file
, except for package name, logging levels etc.
My problem is that in most launch attempts
ros2 launch diffbot_pico diffbot.launch.py
, the launch process "hangs" until Ctrl+C at the joint_state_broadcaster node:
[spawner-3] [DEBUG] [1696274031.543300764] [spawner_joint_state_broadcaster]: requester: making request: controller_manager_msgs.srv.SwitchController_Request(activate_controllers=['joint_state_broadcaster'], deactivate_controllers=[], start_controllers=[], stop_controllers=[], strictness=2, start_asap=False, activate_asap=True, timeout=builtin_interfaces.msg.Duration(sec=5, nanosec=0))
[spawner-3]
[spawner-3] [DEBUG] [1696274031.543453746] [rcl]: Client sending service request
[spawner-3] [DEBUG] [1696274031.544023770] [rcl]: Initializing wait set with '0' subscriptions, '2' guard conditions, '0' timers, '4' clients, '6' services
After n launch attempts, the broadcaster activation suddenly succeeds, and the launch procedure goes on to activate the diffbot_base_controller etc. On those occasions, RVIZ is opened as expected, and all communication to Micro-ROS/ microcontroller is OK.
[spawner-3] [DEBUG] [1696274031.720523369] [rcl]: Client taking service response
[spawner-3] [DEBUG] [1696274031.720603413] [rcl]: Client take response succeeded: true
[spawner-3] [INFO] [1696274031.722087080] [spawner_joint_state_broadcaster]: Configured and activated joint_state_broadcaster
I'm not sure if this is relevant, but these errors show up early in the launch log:
[spawner-3] [DEBUG] [1696274031.151595044] [rcl]: Couldn't parse arg 0 (/opt/ros/humble/lib/controller_manager/spawner) as a remap rule in its deprecated form. Error: Expected lexeme type (19) not found, search ended at index 46, at ./src/rcl/lexer_lookahead.c:239
[spawner-3] [DEBUG] [1696274031.151611839] [rcl]: Couldn't parse arg 1 (joint_state_broadcaster) as a remap rule in its deprecated form. Error: Expected lexeme type (19) not found, search ended at index 23, at ./src/rcl/lexer_lookahead.c:239
[spawner-3] [DEBUG] [1696274031.151615583] [rcl]: Couldn't parse arg 2 (--controller-manager) as a remap rule in its deprecated form. Error: Expecting token or wildcard, at ./src/rcl/arguments.c:1170
[spawner-3] [DEBUG] [1696274031.151618769] [rcl]: Couldn't parse arg 3 (/controller_manager) as a remap rule in its deprecated form. Error: Expected lexeme type (19) not found, search ended at index 19, at ./src/rcl/lexer_lookahead.c:239
I also got the debugger module connected to the Pico, and when the launch file hangs, there is NO TX/RX indication (LED). On succesful attempts, the TX/RX indicators immediately indicate traffic.
Anyone having related experience in this kind of arbitrary launch error?
8
  • $\begingroup$ Hi. Could you please add information on which release you are using? You link to the master branch of the demos, do you use iron or rolling? $\endgroup$ Oct 3, 2023 at 8:31
  • $\begingroup$ Sorry, I forgot. I am using Humble $\endgroup$ Oct 3, 2023 at 18:54
  • $\begingroup$ ok, that should not change anything regarding the controller_manager or spawner. $\endgroup$ Oct 3, 2023 at 20:21
  • $\begingroup$ can you explain your architecture more in detail? I never worked with micro-ROS, where do you launch the controller_node of ros2_control? Where is the data transferred from your PC to micro-ROS? $\endgroup$ Oct 3, 2023 at 20:30
  • $\begingroup$ I took inspiration from the ROSCON 22 workshop code, and the work of Josh Newman, and have a separate comms header file. In there, I initialize some ROS2 publishers, and a ROS2 client, using the custom interfaces installed both on the ROS2 workspace, and in the micro-ROS workspace on the Pico. It's more or less the same code as found in the ROS2 tutorials, for writing custom publisher and custom client. The communication is managed via a micro-ROS agent, running in a Docker container on the client/ host PC. Happy to share my work, when it's less buggy :) $\endgroup$ Oct 7, 2023 at 19:11
I don't use the debug log-level a lot, normally I was able to solve such problems with the standard Info/Warn/Error messages.
I suggest the following:
  • Change your launch file to a minimum, i.e., do not activate any controllers (outcomment the spawners) and launch it.
  • Use the ros2_control CLI to introspect the controller manager's state. The CLI commands are only python wrappers for the services provided by the controller manager. If there is a problem, you will also see this with the CLI commands.
  • Follow the points from literal 6 of RRbot example_1 (load controller, configure, activate) and see if you can reproduce and isolate your issue.
  • $\begingroup$ thanks for taking the time to answer, I will look at your suggestions tomorrow $\endgroup$ Oct 7, 2023 at 18:58
