my problem is basically about tf_fransformations
package. I installed and changed all dependencies according to enter link description here, but it is not working. I used transforms3d
to import the related things. Could you help us about that problem. I added the related code in our python files below, If needs I can share more, thanks.
terminal output:
ntukenmez3@ae-icps-407120:~/Documents/2023-crazy-flie/crazyflie_ros2_experimental/crazyflie_ros2$ ros2 launch crazyflie_ros2 crazyflie_publisher_launch.py
[INFO] [launch]: All log files can be found below /home/ntukenmez3/.ros/log/2023-10-01-16-07-47-625647-ae-icps-407120-3378000
[INFO] [launch]: Default logging verbosity is set to INFO
[INFO] [crazyflie_publisher-1]: process started with pid [3378004]
[crazyflie_publisher-1] Traceback (most recent call last):
[crazyflie_publisher-1] File "/home/ntukenmez3/Documents/2023-crazy-flie/crazyflie_ros2_experimental/crazyflie_ros2/install/crazyflie_ros2/lib/crazyflie_ros2/crazyflie_publisher", line 33, in
[crazyflie_publisher-1] sys.exit(load_entry_point('crazyflie-ros2==0.0.0', 'console_scripts', 'crazyflie_publisher')())
[crazyflie_publisher-1] File "/home/ntukenmez3/Documents/2023-crazy-flie/crazyflie_ros2_experimental/crazyflie_ros2/install/crazyflie_ros2/lib/crazyflie_ros2/crazyflie_publisher", line 25, in importlib_load_entry_point
[crazyflie_publisher-1] return next(matches).load()
[crazyflie_publisher-1] File "/usr/lib/python3.10/importlib/metadata/init.py", line 171, in load
[crazyflie_publisher-1] module = import_module(match.group('module'))
[crazyflie_publisher-1] File "/usr/lib/python3.10/importlib/init.py", line 126, in import_module
[crazyflie_publisher-1] return _bootstrap._gcd_import(name[level:], package, level)
[crazyflie_publisher-1] File "", line 1050, in _gcd_import
[crazyflie_publisher-1] File "", line 1027, in _find_and_load
[crazyflie_publisher-1] File "", line 1006, in _find_and_load_unlocked
[crazyflie_publisher-1] File "", line 688, in _load_unlocked
[crazyflie_publisher-1] File "", line 883, in exec_module
[crazyflie_publisher-1] File "", line 241, in _call_with_frames_removed
[crazyflie_publisher-1] File "/home/ntukenmez3/Documents/2023-crazy-flie/crazyflie_ros2_experimental/crazyflie_ros2/install/crazyflie_ros2/lib/python3.10/site-packages/crazyflie_ros2/crazyflie_publisher.py", line 6, in
[crazyflie_publisher-1] from transforms3d import *
[crazyflie_publisher-1] ModuleNotFoundError: No module named 'transforms3d'
[ERROR] [crazyflie_publisher-1]: process has died [pid 3378004, exit code 1, cmd '/home/ntukenmez3/Documents/2023-crazy-flie/crazyflie_ros2_experimental/crazyflie_ros2/install/crazyflie_ros2/lib/crazyflie_ros2/crazyflie_publisher --ros-args'].
Python files:
1.crazyflie_publisher.py:
import rclpy
from rclpy.node import Node
from geometry_msgs.msg import Pose
#from tf_transformations import euler_from_quaternion
from tf2_ros import TransformBroadcaster
from geometry_msgs.msg import TransformStamped
from sensor_msgs.msg import Range
from sensor_msgs.msg import LaserScan
from nav_msgs.msg import Odometry
from geometry_msgs.msg import Twist
import cflib.crtp # noqa
from cflib.crazyflie import Crazyflie
from cflib.crazyflie.log import LogConfig
from cflib.utils import uri_helper
from cflib.crazyflie.syncCrazyflie import SyncCrazyflie
from cflib.positioning.motion_commander import MotionCommander
import math
from math import pi
URI = uri_helper.uri_from_env(default='radio://0/80/2M/E7E7E7E7E7')
FLYING = True
def radians(degrees):
return degrees * math.pi / 180.0
class CrazyfliePublisher(Node):
def __init__(self, link_uri):
super().__init__('crazyflie_publisher')
#self.pose_publisher = self.create_publisher(Pose, 'pose', 10)
self.range_publisher = self.create_publisher(Range, 'zrange', 10)
self.laser_publisher = self.create_publisher(LaserScan, 'scan', 10)
self.odom_publisher = self.create_publisher(Odometry, 'odom', 10)
self.create_subscription(Twist, 'cmd_vel', self.cmd_vel_callback, 1)
self.tfbr = TransformBroadcaster(self)
self._cf = Crazyflie(rw_cache='./cache')
self._cf.connected.add_callback(self._connected)
self._cf.disconnected.add_callback(self._disconnected)
self._cf.connection_failed.add_callback(self._connection_failed)
self._cf.connection_lost.add_callback(self._connection_lost)
self._cf.open_link(link_uri)
self.ranges= [0.0, 0.0, 0.0, 0.0, 0.0]
self.create_timer(1.0/30.0, self.publish_laserscan_data)
if FLYING:
timer_period = 0.1 # seconds
self.create_timer(timer_period, self.sendHoverCommand)
self.hover = {'x': 0.0, 'y': 0.0, 'z': 0.0, 'yaw': 0.0, 'height': 0.3}
self._cf.commander.send_hover_setpoint(
self.hover['x'], self.hover['y'], self.hover['yaw'],
self.hover['height'])
def publish_laserscan_data(self):
msg = LaserScan()
msg.header.stamp = self.get_clock().now().to_msg()
msg.header.frame_id = 'base_link'
msg.range_min = 0.01
msg.range_max = 3.49
msg.ranges = self.ranges
msg.angle_min = 0.5 * 2*pi
msg.angle_max = -0.5 * 2*pi
msg.angle_increment = -1.0*pi/2
self.laser_publisher.publish(msg)
def sendHoverCommand(self):
hover_height = self.hover['height'] + self.hover['z']*0.1
hover_height)
self.hover['height'] = hover_height
def _connected(self, link_uri):
self.get_logger().info('Connected!')
self._lg_stab = LogConfig(name='Stabilizer', period_in_ms=100)
self._lg_stab.add_variable('stateEstimate.x', 'float')
self._lg_stab.add_variable('stateEstimate.y', 'float')
self._lg_stab.add_variable('stateEstimate.z', 'float')
self._lg_stab.add_variable('stabilizer.roll', 'float')
self._lg_stab.add_variable('stabilizer.pitch', 'float')
self._lg_stab.add_variable('stabilizer.yaw', 'float')
self._lg_range = LogConfig(name='Range', period_in_ms=100)
self._lg_range.add_variable('range.zrange', 'uint16_t')
self._lg_range.add_variable('range.front', 'uint16_t')
self._lg_range.add_variable('range.right', 'uint16_t')
self._lg_range.add_variable('range.left', 'uint16_t')
self._lg_range.add_variable('range.back', 'uint16_t')
try:
self._cf.log.add_config(self._lg_stab)
self._lg_stab.data_received_cb.add_callback(self._stab_log_data)
self._lg_stab.error_cb.add_callback(self._stab_log_error)
self._lg_stab.start()
self._cf.log.add_config(self._lg_range)
self._lg_range.data_received_cb.add_callback(self._range_log_data)
self._lg_range.error_cb.add_callback(self._range_log_error)
self._lg_range.start()
except KeyError as e:
print('Could not start log configuration,'
'{} not found in TOC'.format(str(e)))
except AttributeError:
print('Could not add Stabilizer log config, bad configuration.')
def _disconnected():
print('disconnected')
def _connection_failed(self, link_uri, msg):
print('connection_failed')
def _connection_lost(self, link_uri, msg):
print('connection_lost')
def _range_log_error(self, logconf, msg):
"""Callback from the log API when an error occurs"""
print('Error when logging %s: %s' % (logconf.name, msg))
def _range_log_data(self, timestamp, data, logconf):
"""Callback from a the log API when data arrives"""
for name, value in data.items():
print(f'{name}: {value:3.3f} ', end='')
print()
t_range = TransformStamped()
q = tf_transformations.quaternion_from_euler(0, radians(90), 0)
t_range.header.stamp = self.get_clock().now().to_msg()
t_range.header.frame_id = 'base_link'
t_range.child_frame_id = 'crazyflie_flowdeck'
t_range.transform.rotation.x = q[0]
t_range.transform.rotation.y = q[1]
t_range.transform.rotation.z = q[2]
t_range.transform.rotation.w = q[3]
self.tfbr.sendTransform(t_range)
zrange = float(data.get('range.zrange'))/1000.0
msg = Range()
msg.header.frame_id = 'crazyflie_flowdeck'
msg.field_of_view = radians(4.7)
msg.radiation_type = Range().INFRARED
msg.min_range = 0.01
msg.max_range = 3.5
msg.range = zrange
##self.range_publisher.publish(msg)
max_range = 3.49
front_range = float(data.get('range.front'))/1000.0
left_range = float(data.get('range.left'))/1000.0
back_range = float(data.get('range.back'))/1000.0
right_range = float(data.get('range.right'))/1000.0
if front_range > max_range:
front_range = float("inf")
if left_range > max_range:
left_range = float("inf")
if right_range > max_range:
right_range = float("inf")
if back_range > max_range:
back_range = float("inf")
self.ranges = [back_range, left_range, front_range, right_range, back_range]
def cmd_vel_callback(self, twist):
self.target_twist = twist
self.hover['x'] = twist.linear.x
self.hover['y'] = twist.linear.y
self.hover['z'] = twist.linear.z
self.hover['yaw'] = -1* math.degrees(twist.angular.z)
def _stab_log_error(self, logconf, msg):
def _stab_log_data(self, timestamp, data, logconf):
"""for name, value in data.items():
print()"""
msg = Odometry()
x = data.get('stateEstimate.x')
y = data.get('stateEstimate.y')
z = data.get('stateEstimate.z')
roll = radians(data.get('stabilizer.roll'))
pitch = radians(-1.0 * data.get('stabilizer.pitch'))
yaw = radians(data.get('stabilizer.yaw'))
msg.pose.pose.position.x = x
msg.pose.pose.position.y = y
msg.pose.pose.position.z = z
q = tf_transformations.quaternion_from_euler(roll, pitch, yaw)
msg.pose.pose.orientation.x = q[0]
msg.pose.pose.orientation.y = q[1]
msg.pose.pose.orientation.z = q[2]
msg.pose.pose.orientation.w = q[3]
self.odom_publisher.publish(msg)
q_base = tf_transformations.quaternion_from_euler(0, 0, yaw)crazyflie_publisher.py:
t_base = TransformStamped()
t_base.header.stamp = self.get_clock().now().to_msg()
t_base.header.frame_id = 'odom'
t_base.child_frame_id = 'base_footprint'
t_base.transform.translation.x = x
t_base.transform.translation.y = y
t_base.transform.translation.z = 0.0
t_base.transform.rotation.x = q_base[0]
t_base.transform.rotation.y = q_base[1]
t_base.transform.rotation.z = q_base[2]
t_base.transform.rotation.w = q_base[3]
self.tfbr.sendTransform(t_base)
t_odom = TransformStamped()
t_odom.header.stamp = self.get_clock().now().to_msg()
t_odom.header.frame_id = 'odom'
t_odom.child_frame_id = 'base_footprint'
q_odom = tf_transformations.quaternion_from_euler(0, 0, 0)
t_odom.transform.translation.x = 0.0
t_odom.transform.translation.y = 0.0
t_odom.transform.translation.z = 0.1
t_odom.transform.rotation.x = q_odom[0]
t_odom.transform.rotation.y = q_odom[1]
t_odom.transform.rotation.z = q_odom[2]
t_odom.transform.rotation.w = q_odom[3]
#self.tfbr.sendTransform(t_odom)
t_cf = TransformStamped()
q_cf = tf_transformations.quaternion_from_euler(roll, pitch, 0)
t_cf.header.stamp = self.get_clock().now().to_msg()
t_cf.header.frame_id = 'base_footprint'
t_cf.child_frame_id = 'base_link'
t_cf.transform.translation.x = 0.0
t_cf.transform.translation.y = 0.0
t_cf.transform.translation.z = z
t_cf.transform.rotation.x = q_cf[0]
t_cf.transform.rotation.y = q_cf[1]
t_cf.transform.rotation.z = q_cf[2]
t_cf.transform.rotation.w = q_cf[3]
self.tfbr.sendTransform(t_cf)
def main(args=None):
cflib.crtp.init_drivers()
rclpy.init(args=args)
crazyflie_publisher = CrazyfliePublisher(URI)
rclpy.spin(crazyflie_publisher)
crazyflie_publisher.destroy_node()
rclpy.shutdown()
if __name__ == '__main__':
main()
2.package.xml:
<?xml version="1.0"?>
<?xml-model href="http://download.ros.org/schema/package_format3.xsd" schematypens="http://www.w3.org/2001/XMLSchema"?>
<package format="3">
<name>crazyflie_ros2</name>
<version>0.0.0</version>
<description>Publishing Crazyflie Logging Variables</description>
<maintainer email="[email protected]">knmcguire</maintainer>
<license>MIT</license>
<exec_depend>python3-cflib</exec_depend>
<exec_depend>rclpy</exec_depend>
<exec_depend>std_msgs</exec_depend>
<exec_depend>geometry_msgs</exec_depend>
<exec_depend>transforms3d</exec_depend>
<exec_depend>python-transforms3d-pip</exec_depend>
<exec_depend>tf2_ros</exec_depend>
<exec_depend>sensor_msgs</exec_depend>
<exec_depend>nav_msgs</exec_depend>
<test_depend>ament_copyright</test_depend>
<test_depend>ament_flake8</test_depend>
<test_depend>ament_pep257</test_depend>
<test_depend>python3-pytest</test_depend>
<export>
<build_type>ament_python</build_type>
</export>
</package>
3.setup.py:
from setuptools import setup
import os
from glob import glob
package_name = 'crazyflie_ros2'
data_files=[
('share/ament_index/resource_index/packages',
['resource/' + package_name]),
('share/' + package_name, ['package.xml']),
def package_files(data_files, directory_list):
paths_dict = {}
for directory in directory_list:
for (path, directories, filenames) in os.walk(directory):
for filename in filenames:
file_path = os.path.join(path, filename)
install_path = os.path.join('share', package_name, path)
if install_path in paths_dict.keys():
paths_dict[install_path].append(file_path)
else:
paths_dict[install_path] = [file_path]
for key in paths_dict.keys():
data_files.append((key, paths_dict[key]))
return data_files
setup(
name=package_name,
version='0.0.0',
packages=[package_name],
data_files=package_files(data_files, [ 'resource/', 'launch/']),
install_requires=['setuptools'],
zip_safe=True,
maintainer='knmcguire',
maintainer_email='[email protected]',
description='Publishing Crazyflie Logging Variable',
license='MIT',
tests_require=['pytest'],
entry_points={
'console_scripts': [
'crazyflie_publisher = crazyflie_ros2.crazyflie_publisher:main',
