For a specific ROS2 (humble) node that I'm working on I want to add a second logger that just logs to a file (preferably its own). Setting up a second logger is straightforward, as one can just call rclcpp::get_logger('<logger-name>'). I could, however, not find any way to set the logger up so that it just logs to its own file. I do not want the logger to log to the terminal at all.
Thanks!
Short answer:
Re. separate log files:
It is not currently possible to log to two separate files from one node. To realize this, you'd have to implement an alternative rcl_logging_interface.
(Multiple nodes in different processes do log to different files but that is not your use case.)
Re. disabling logging to stdout:
It is possible to disable output to stdout with the ros-args flag --disable-stdout-logs. E.g. for the demo_nodes_cpp example:
ros2 run demo_nodes_cpp list_parameters --ros-args --disable-stdout-logs
In case of the DEBUG loglevel, some messages for rcl and rclcpp are still shown, e.g.:
ros2 run  demo_nodes_cpp list_parameters --ros-args --log-level DEBUG --disable-stdout-logs
If you don't need DEBUG loglevel for rcl and rclcpp (e.g. you only need DEBUG for your nodes), then the stray stdout logmessages can avoided by specifying non-DEBUG loglevels for rcl and rclcpp:
ros2 run  demo_nodes_cpp list_parameters --ros-args --log-level DEBUG --disable-stdout-logs --log-level rcl:=INFO --log-level rclcpp:=INFO
Longer answer:
This is indeed what you'd expect based on the class name 'Logger', but it is not correct. An rclcpp::Logger does not perform any logging, it is just a small class mainly holding a name and providing some methods such as set_level(Level level), but nothing more. The logging is done solely through the log macros, e.g. RCLCPP_INFO(), which resolve to rcutils function calls.
A while ago, I dug through the whole logging code and wrote down an almost complete walktrough in this document. Mind you, this is more or less a literal chronological writedown of digging through the code (i.e. not ideally structured as documentation) and there have been some changes to the code since I wrote that document, so it is not fully up to date anymore. Nevertheless: afaik it still is the best documentation on rclcpp logging currently availabe.
I won't go through the details here, but this section describes the three current output handlers: to console / publish on topic rosout / to file. The 'to file' output handler is described in this subsection. To allow for logging to multiple files you'd need to adapt the rcl_logging_spdlog library or write a similar library and load that as the log handler.
  • $\begingroup$ An alternative to writing a custom rcl_logging_interface could be to implement subscribers to /rosout and have those write the log messages to file. If you'd decide to go that route, be sure to read the section on the /rosout publisher since named loggers do not output to /rosout. $\endgroup$
    – JRTG
    Oct 1 at 16:43
  • $\begingroup$ Thank you! We're in the process of migrating something from our own framework to ROS and in our own framework it was natural to have multiple loggers (e.g. one with DEBUG log level going to file only and one with INFO level going to stdout and file), so I assumed that would be a use case that would be way more common and covered by default. $\endgroup$
    – snoato
    Oct 2 at 7:20
  • $\begingroup$ Ok that is an even more stringent requirement: a logger's log level is evaluated before the log handler is called, and the current log handler does just call each enabled handler without further discriminating on log level. $\endgroup$
    – JRTG
    Oct 2 at 11:07
