I am trying to use the following as input values to an arg command in my roslaunch file as follows:
  <arg name="x_pos" value="3.0"/>
  <arg name="y_pos" value="4.0"/>
  <arg name="z_pos" value="0.0"/>
  <arg name="yaw" value="0.0"/>
However, the doubles I entered do not show up when I try to access them from my C++ node; I read the arg attributes and they do not mention anything about the type of value. Is it by default only string? If that's the case, how do I pass in the doubles so that I can access them in my C++ node?
  • $\begingroup$ Please edit your question to show us your launch file xml which writes the value to the parameter server. $\endgroup$
    – Mike973
    Sep 28 at 21:20
As there is no C++ code mentioned in the question, I wonder if I understood your requirements correctly. However, I never faced issues with integers or double datatypes with the ROS launch file. Below is a code snippet:
ROS launch file:
  <!-- your integer arguments -->
  <arg name="k_neighbors" default="10"/>
  <arg name="max_itr" default="1000"/>
  <!-- your double arguments -->
  <arg name="weight" default="0.05"/>
  <arg name="d_thresh" default="0.005"/>
  <arg name="prob" default="0.99999"/>
  <!-- your float arguments -->
  <arg name="radius" default="0.05"/>
  <!-- your string arguments -->
  <arg name="limb" default="right"/>
C++ node:
  ros::init(argc, argv, "my_node");
  ros::NodeHandle nh("~");
  // define integer parameter and then fetch their values from parameter server
  int k_neighbors, max_itr;
  nh.getParam("k_neighbors", k_neighbors);
  nh.getParam("max_itr", max_itr);
  // define double parameter and then fetch their values from parameter server
  double weight, d_thresh, prob;
  nh.getParam("weight", weight);
  nh.getParam("d_thresh", d_thresh);
  nh.getParam("prob", prob);
  // define float parameter and then fetch their values from parameter server
  float sphere_radius;
  nh.getParam("radius", sphere_radius);
  // define string parameter and then fetch their values from parameter server
  std::string limb;
  nh.getParam("limb", limb);
  // rest of your logic goes here
  return 0;
You may look for launch file and C++ node.
I looked at github issue "Can't pass in a numerical string as arg param to C++ node" and found that putting single quotes around the double, within double quotes, works:
  <arg name="x_pos" value="'3.0'"/>
  <arg name="y_pos" value="'4.0'"/>
  <arg name="z_pos" value="'0.0'"/>
  <arg name="yaw" value="'0.0'"/>
    $\begingroup$ This is ugly, and requires users of your launch file to remember that some args need weird quoting to be done. If you really want to force a property to be a string on the parameter server, then specify that in a param tag: <param name="x_pos" type="str" value="$(arg x_pos)" />. $\endgroup$
    – Mike973
    Sep 30 at 12:23
