Setup :
- ROS2 Humble
- Yocto Distro
- Jetson Nano
- diff_drive_controller : 2.23.0
- controller_manager : 2.28.0
I have a python node publishing cmd_vel to a twist_mux and then to ros2_control. After a random (seems random) period of time, it seems that no cmd_vel are published and consequently motors are not running anymore. If I use the command ros2 topic echo
on the command vel topic, it starts working again. Can you help me understand this behavior ?
Update :
Everything is running on the jetson nano so it isn't a network issue. What I saw this morning is that when it happens the twist_mux seems asleep (I can't see it as a publisher when doing ros2 topic info) BUT it restarts everything and if I re-enter the same "ros2 topic info" command, twist_mux is among the publishers... So it is either a DDS issue either a twist_mux... That's my conclusions for now..
Thanks in advance.
cmd_vel
messages from some external computer, there is a possibility that either you have an internet issue, which means some commands are not being sent over to your Nano, or your DDS is dropping these messages for some reason. $\endgroup$/home/antoine/.ros/log
) are stored. Examine the files from your latest run, this might give you some insight if the DDS fails at some point. Look inside thelaunch.log
file to see if anything suspicious pops up there, if not, then go on to check the controller manager's logs. I would also suggest that you open an issue on theros2_control
repo. You will find more dedicated support from the maintainers there. $\endgroup$
