Is it possible to construct a goal with pose constraints via MoveIt python binding?
I have realized this with
moveit_msgs::Constraints pose_goal = kinematic_constraints::constructGoalConstraints("panda_hand_tcp", pose, tolerance_position, tolerance_orientation);
where tolerance_position and tolerance_orientation are both vectors.
But it seems that when using Python binding, tolerance_position and tolerance_orientation can only be a number instead of an array.
Should I generate the corresponding Python binding based on the Moveit source code?
Any help would be appreciated! Thanks!
